Hi All,
I am going to install some garrett turbos on my gtr and will be looking for around 300-330 rwkw and am trying to avoid the cost of buying Nismo AFM's. I read an old article that Tillbrook Automotive in SA (I think) removed the screens standard AFM's, which allowed a bit more resolution with tuning.
Does anyone else agree with this method for what I am chasing or should I be buying Nismo AFM's?
https://www.sau.com.au/forums/topic/307907-removing-gtr-afm-screens/
Wait and see how your current afm's hold up before spending money on replacements.
My factory afm's were fine up to 350awkw in my last GTR.
Aside from that, i can't see how there would be any great benefit in removing the mesh.
Thanks Nick.
The article quoted the following food for thought;
de-screen the existing 65mm afm's, which adds around 8% cross-sectional area. This is enough that the tuning process with the Power FC is given more resolution at boost levels close to 1.5 bar.
I will just leave them as they are then and see how it goes.
Interesting.
Though I have heard of it being done, if I got to the stage where I was maxing my current afm's I would rather replace them all together than remove the mesh, as I see that as more of a bandaid solution.
I guess it also comes down to the car and tune in question - If modifying the stockers works in your situation, great :sick:
or put a Vi-pec plug-in in it and throw the bastards away.
Whats a Vi-Pec worth? Would also have to plug in a Map Sensor?
No real disadvantages with getting rid of AFM's?
Edited by gtr fan
removing the mesh would achieve zero, if anything as status said, it would cause reversion and probably make it run worse
you can stretch the point at where an AFM maxes, so effectively keep using it even though it maxes out (MAP sensor style) and it is OK, but if you max the AFM at 4000prm this is bad and you need to change to larger scale items. maxing them at 6700rpm is probably OK (map sensor style).
please run up on map sensors and how they work before going to them just because, you can probably make 300rwkw OK with the stock afms
They max out around 280-300rwkw. However if your tuner is decent and you trust them... you can tune past the max.
It's certainly been done before!
Just be warned though that in varying temp conditions, the tune won't be 100% so it'll be "safer" past the max point that you would otherwise have if AFM's were replaced.
IMO just get the Nismo AFM's from perfectrun.
At the end of the day, your AFM's are more than likely dying anyway after 10+ years. So little "quirks" during tuning can pop up, even intermittent problems you can spend months chasing only to find out its a AFM playing silly games
And still 2nd hand, which presents the same issues still with regards to reliability and failure.
Seems around the 10years marker that they start to degrade. Obviously a broad assumption (some sooner, some last longer).
But given the issues i've seen with people & AFM's, after 10 years especially if you are upgrading parts for more performance... AFM's are just a given to chance to brand new items.
TBH i agree, most of the tuning issue's we run into with skylines revolve around coilpacks and afm's.
yes and remember that rb20 or rb25 afms still max out at the same airflow...they just have larger cross section. you need to decide which problem you are trying to solve - restriction (get rb25 or rb20 ones) or outside the resolution/over 5v (get z32 or nismo ones)
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
