Here ya go, all you need to know about rotaries:
http://www.skylinesaustralia.com/forums/Ro...ck-t287781.html
rotaries are quite stable, efficient and reliable in stock N/A form. its only when tards thrash the living daylights out of twin turbo variants that you get reliability issues.
Wow, that was... er... informative.
Still, mostly there seems to be an agreement that they are little poorly on the torque unless they are turbo'd, so I think I'll stick with what I sort of understand, which in this case appears to be a reasonably well built straight 6 that does not eat three dinosaurs every five miles.
Mind you, whatever you think of the exhaust note of a rotary, it would be pretty darn suprising coming from an old bus leaving the lights with the duals smoking nicely...
VS ecotec and onwards feel the most refined of the 3.8 litre engines to me. They were at their most powerful (in factory form) from this point onwards and also pretty easy to find in long block form. All buick 3800 engines have a ton of interchangeable parts; heads off one onto blocks of another etc. Nice compact engines, not too difficult to work on. Maybe just give it some research first and see how feasible it is for you.
Avoid the T5 gearboxes for towing...they will stand up as a daily or to carry light loads, but it's not uncommon to break teeth in heavy duty applications. The T5 was superseded by the Getrag 260 (AKA M34, a 5 speed European made BMW style gearbox) which came in the VS series 2/3, VT, VX and VY Commodores with V6 engines - these are fairly strong gearboxes and would be up for towing, but some have oil supply issues and they cost a pretty penny to repair if something goes wrong. Seeing you're doing an engine/gearbox conversion anyway, I'd opt for something like a Supra 5 speed (can get some nice short bus/truck ratios in the W55 version, plus there are kits out there to fit them to any vehicle/engine)...or a T56 from an LS engined Holden if you can afford it.
I wasn't ragging on rotaries, just giving him the 50 page thread that if one has the patience to read past the first page will teach you nearly everything you need to know about rotaries lol.
Avoid the T5 gearboxes for towing...they will stand up as a daily or to carry light loads, but not uncommon to break teeth in heavy duty applications. Seeing you're doing an engine/gearbox conversion anyway, I'd opt for something like a Supra 5 speed (can get some nice short bus ratios in the W55)...or a T56 if you can afford it.
Great advice, thank you.
on the fuel economy for a second, a falcon motor towing a caravan or anything like that will obviously use more fuel, but not that much more than what a rb30 will. also the extra fuel economy is only partly due to the extra weight but more to do with the massive increase in drag caused by towing a car on a trailer or a caravan, and the extra rolling resistance of the tyres. stick the motor in a bus and it will perform differently.
also if using a falcon or commodore motor i would have it reving a bit higher on the highway than the car it came out of. this will actually help a bit with fuel economy. you will be reving higher but you won't be labouring the motor as much so will be using less throttle % and therefore less fuel. that is the problem with the aussie motors. the diffs in them are so tall that the moment they get any sort of load on them the fuel economy goes to shit. despite the fact that they are only reving low you still have your foot a fair way down. but get them higher in the revs but with less throttle and they aren't that bad. in the standard car they will use under 10L/100km on the highway without a trailer on.
if you were to use an auto box out of the commodore or falcon, just make sure to fit an oil cooler. if going a manual i would get a heavy duty clutch as well.
as for commodores cracking heads, etc, that was mainly in the earlier models, like vn's etc, and was generally caused by people raping the arse out of them.
talking about the diesels, yes they will take reving at high revs for ages. my mate had an old nissan navara diesel that used to rev at 4200rpm on the highway. was slow as buggery though, even after the engine was rebuilt. if going to go diesel i would go a 4.2L out of the later model patrols, but they will set you back more money than you are probably willing to spend.
    • 2 spots that my exhaust guy joined the 2 pipes together  Made a big difference. I'm now able to live with it. I can make it louder if I want by removing the HKS caps.
    • Hi all, considering clutch upgrade to support 1130 engine hp from 1650cc injectors on e50 at 85% duty cycle (1650 x (11.85/14.7) x 85%). Narrows down to these three as they can be converted to use gm 26 spline input shaft if I ever want to use transmission with that input shaft (orc1000f and r3c easy/cheap just change center hub; tr2cd pricier must change clutch discs). Pricing orc1000f similar to tr2cd, r3c about usd 200 pricier. Orc1000f triple plate 200mm. Tr2cd twin plate 215mm. R3c triple plate 215mm. Claimed max torque : orc 1000f 723 lbs ft; tr2cd 800 lbs ft; r3c 1100 lbs ft. Why orc1000f triple plate but claims lower max torque vs tr2cd twins? Is orc1000f underrated? Any info maxing out these clutches? Info on street/traffic driveability/pedal feel? Thank you for any info on them.
    • Some troubleshooting, connect up a timing light/gun with a proper ignition lead on coil 1. Hold the revs at 4~4500rpm and see if your timing is all over the shop, scattering off its tits. If so, there's a high chance your CAS is fked. But I read you have a Link ECU ready to go in, why not just skip all this and put that in - will make troubleshooting so much easier.
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
