Hi,
So im toying with the idea of selling my project car. Its a 1995 R33 GTR with 68,000kms. Has not been driven in 2 years and to be honest im a bit over it.
All parts are brand new unless stated. Car is 80% complete just needs wiring, piping, interior installed, and a run in.
Motor is brand new built by Paul @ Red R Racing (aka DiRT Garage)
Engine
05U block (block chemical clean, crack tested, decked, 86.5 bored, and honed)
RIPS NZ baffled 9ltr sump with two #10 return lines
Greddy Oil pump
N1 Water pump
CP Pistons with ACL std rod and main bearings calico coated
TRUST Greddy Strengthened Crank Cap Bolt Stud Set RB26
Eagle ESP H beam rods with ARP rod bolts
Greddy cams 256 duration inlet 9.1 lift, 264 duration exhaust 9.1 lift
Greddy adjustable cam gears
Tomei timing belt
Power Enterprise Kevlar V belt, A/c, and alternator belts
Tomei Gasket Combination Set with 1.2mm metal head gasket
Tomei Oil Gallery Orifice - oil restrictor
New Tension/ pulleys
Head
Head full service
Tomei Valve guides RB26DETT In and Ex
Greddy Valve springs
Tomei Solid Valve Lifters
JUN Titanium Valve Retainers RB26DETT 0 Offset Type I
TRUST Greddy Strengthened Cam Cap Bolt Stud Set
Trust Greddy Strengthened Cylinder Head Bolts
HKS Valve Stem Seals RB26DETT Skyline
Extensive port job
Bolt ons
6boost low mount manifolds
HKS GT2530's and all new braided lines (Earls)
SARD 700cc Fuel Injectors RB26DETT Skyline
SARD Standard Type Adjustable Fuel Regulator #6an (not installed)
Bosch 044 x 2 external, 040 internal, 1.5 ltr surge tank all braided lines (not installed)
Greddy 10.5 fuel rail twin entry
ATI balancer
RIPS Custom 6 throttle plenum
HKS Hard piping kit
2ltr surge tank with earls fittings
HKS Drag cooler
Greddy remote filter + oil cooler
Drive Train Fitted
OS Giken 5 Speed gearbox
HKS GD pro Twin plate
Chromoly one peice tailshaft
6 piston Greddy rotors with 365mm fronts and 330mm 4 piston rears (2000km old)
Nismo titanium strut brace (super rare)
Suspension 1/2 installed.
Ikeya Formula Rear Camber Adjuster Upper Arm
Ikeya Formula Rear Traction Adjuster Rod Nissan
Ikeya Formula Strengthened Tie Rods
Ikeya Formula Front and rear lower control arms
Cusco Upper Arms
Tien Coil overs
Wheels Fitted
18 x 10.5 TE37's (used) with decent tyres. can be supplied with brand new Yokohama 265 A drives.
Electronics None installed
Haltech Platinum Pro plug in with Auxiliary expansion
4 Bar Map
Usual GTR clusters (torque etc)
Ruzic engineering 4WD controller
Greddy Turbo timer
Body
Exterior paint is in good nick,
Engine bay has been welded. smoothed and resprayed to show quality all work done by Louie from Xclusive Colours.
Underbody from the front has been re surfaced and sprayed.
Standard GTR front bar, sides, rear bar and a Do luck drag wing
R33 Series 3 Xenon headlights
Im sure there is a heaps more I have missed.
NSW Rego till July 2010.
Price is $49,000
Cheers,
Johno
