1992 s13 silvia non hicas
tuned at stz automotive northgate
rb25det and rb25det gearbox
1 piece tailshaft
new exeedy 5 puck clutch
garret gt35r.63 rear housing
greddy copy side plenum
gtr injectors
custom twin feed gtr fuel rail with option to run a extra injector
fuel pressure gauge in the rail for precise adjustment
turbosmart fuel pressure regulator
turbosmart 38mm ultra gate external wastegate
gtr intercooler
100mm throttle body
new yellow jacket coil packs
new plugs
new haltech e11v2
new haltech 3 bar map sensor
electronic boost controll with haltech
3 inch dump through to a 2 3/4 cat then into 3inch to the cannon at the rear cat still intact
5 stud front and rear
4 pot front and 2 pot rear brakes [r32]
shimmed r200 diff perfect never opens
set of dmax 17x8 front 17x9 rear wheels
set of standard r32 rims
aftermarket shocks with king springs
car has dent in front rh gaurd and small dent rh rear
car is fully mod plated and regesterable was my daily...
car makes 260hp on 6psi, 330hp at 14psi and 370hp at 17psi atw. i have the dyno graph from stz.
car will go over 400hp atw if you want to but 370 is safe and reliable as its my daily driver and 370hp in a s13 is a lot of power!!!!!!
will swap for a r32,s13 and 3-4 cash my way or $10000 ono cheap for cash as i need $$$$
ph 0437834932
post-38467-1265950783_thumb.jpgpost-38467-1265950798_thumb.jpgpost-38467-1265950806_thumb.jpgpost-38467-1265950815_thumb.jpgpost-38467-1265950822_thumb.jpgpost-38467-1265950831_thumb.jpgpost-38467-1265950842_thumb.jpgpost-38467-1265950854_thumb.jpg
https://www.sau.com.au/forums/topic/307960-s13-1992-370hp-atw-cheeeeeeeep/
