Vaccum leak.. check all the little hoses under the throttlebody.
At my last service my throttlebody was removed and cleaned and it fixed up that exact issue, so it's probably what bubba said, but I've heard a lot of people point to bov issues...
https://www.sau.com.au/forums/topic/307997-help/page/2/#findComment-5087649
i had a similar issue where when it would drop, it would drop straight down the stall, or bounce a bit at 500rpm and die or go back to normal idle, what i did was increase the idle revs and that solved it
Mine was doing this for a while. Mainly when it was up to normal operating temp. Would be sitting at the lights idling, idle would start hunting and boost guage flapping around too of course, then if I gave throttle a stab it'd settle down, but if I didn't it'd stall. Ended up being intake manifold gasket.
While you're at it with the carby cleaner on the AFM, have your car idling (if possible) and spray a bit of the carby cleaner around your intake manifold and if your car's rev's suddenly pick up, could have a leak. Otherwise, scratch another possibility off the list :thumbsup:
Good luck.
-Chris
https://www.sau.com.au/forums/topic/307997-help/page/2/#findComment-5088072
Yeah my money is still on a vaccum leak.. the common areas to look for the leak are vaccum hoses (there are some fiddly little ones under the throttlebody, I had one that kept popping off giving me the same symptoms the OP is quoting), throttlebody gasket, intake manifold gasket (between the halves).
As stormy suggested, get the carby cleaner out and start spraying.
As others have suggested it could be fuel pump/filter related, particularly fuel pump if you still have the stocker with the variable voltage feed.
https://www.sau.com.au/forums/topic/307997-help/page/2/#findComment-5088597
Hey mate i had the exact same thing for awhile, was very dangerous especially when car would cut out while going around corners meaning no power steering or even brakes as these all depend on the car being on. It only started happening after i put a BOV on and had a custom Stainless steel Air intake pipe installed that replaced the original rubber piping. The rubber piping is designed with contour design that helps prevent air being forced back out the wrong way. So when my foot was down it would suck in air as it should past the AFM than the moment i remove my foot the left over air would rush back down the pipe causing the AFM to think something arong and causing the car to stall.
I was also told it may be a BOV issue but i had a small almost reverb cone installed inside the pipe and since than i have not had any problems since. Not that costly and helped.
Good luck with your problem mate im sure you will find the exact cause of your problem on here soon.
https://www.sau.com.au/forums/topic/307997-help/page/2/#findComment-5088611
By the way a temp fix is to always blip the throttle a bit when going into neutral, well it was for me anyway... Sometimes needed two blips but didn't ever fully stall after I found that out :(
Edited by Psyrus
https://www.sau.com.au/forums/topic/307997-help/page/2/#findComment-5092917
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
