Nissan Skyline R32 Mspec 1990
rb25 head with rb30 bottom end
rb25 gearbox
custom tailshaft
garret gt30/82 turbo .7 front 1.03 back
turbosmart 45mm progate with screamer pipe
spitfire coil packs
800cc injectors
500hp bosch fuel pump
Fuel regulator
GTR brakes with slotted disk
Tein adustable coil overs with damper adjusters
3inch exhaust with highflow cat, quiet for less attraction
greddy style plenum
custom overflow bottle
front mount cooler
custom catch can
microtech lt10
autometer 2 5/8 oil pressure and water temp gauges
2inch boostgauge
battery relocated in boot
blaupaunkt head unit cd
blaupaunkt splits at back
immobilisor/alarm
factory sunroof with central locking
power windows
work cr kai wheels
18x9.5 +17 rears and 18x8.5 +27 fronts
265/40/18 toyo R1R tyres 90percent new
225/35/18 kumho RU19 95percent new
Reg expire 02/09/2010
Runs 272rwkw at 18psi
runs 298rwkw at 21psi
quick car , no test pilots only serious buyers.
Need money deperately asap for house deposit so come grab a bargain.
13000ono no offer refused
call anytime
0401766404 or 94641564 ask for Loc
https://www.sau.com.au/forums/topic/308001-r32-skyline-rb2530-298rwkw/
im in melbourne
its using na head with na bottom end . rebuilt bottom end by transcar prob 11 months ago .
ive only had the car for 3-4 months and old owner had it done 7 -8 months ago before i bought it.
Edited by nxtnl9
hey mate, by any chance, would you be interested in selling your wheels ?
I've got a set of 18's that you can put onto your car after I buy your wheels just in case you need some wheels to go along with the sale.
let me know, cheers
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
