I want to install a master lock actuator motor into the drivers side so it can be operated by alarm. Does anyone know how to wire this into the system, can i wire it to the door relay, which wires would that be? Thanks
https://www.sau.com.au/forums/topic/308008-central-locking-install/
I am a learn as you go mechanic. I thought the door relay was the black box in the drivers door, or is that the power window relay? You say its do able, sounds like its not normal. Where would you normally wire the extra motor to, straight to the alarm?
Edited by levizzle
