Dellorto Rebuild
Has anyone rebuilt their own carby before?
I have had some carby building pro's tell me that my triple Dellortos are full of crap, and they have quoted upwards of $1,600 to rebuild and tune them. They've warned me that if I have a go at doing it myself (at about a tenth of the cost) I'll get it all wrong and will come crawling back to them anyway (and with no experience to my name they may well be right.)
I can buy complete, new triple webers on a Datsun manifold for around $1700, but they wont be jetted to suit my car, so there will still be some additional expenses tuning them.
At this stage I am tempted to buy a book and some gasket kits and have a go myself. Any suggestions?
I can point you to the man who kept my webers on my datto and many others carbs running perfect-
Randy at Nissco: www.nissco.com.au
Address:
Nissco 1600 Workshop
2 Halbert Road
Bayswater North, Victoria 3153
Melways Reference - 51 : B10
Phone:
(03) 9761 4743
Fax:
(03) 9761 4005
International:
+61 3 9761 4743
Email:
[email protected]
Open six days a week.
Hi.
The dellorto and weber are a fixed jet carby so relatively easy to maintain. If they are dirty and you are not sure of doing the job remember they are two identical barrels so take out the jets on one side and you still have the other side for reference. These carbys are not hard to work on.. One point to think about the Dellorto is no longer made . .
If you are not confident take them to the man mentioned above.
I know and trust Randy, but he is way over on the other side of town... Still for the final tuning and jetting he probably is worth the drive.
Thanks for the heads up about doing 1 side at a time. Although the Dellorto carby bodies are no longer made, there is still a bunch of Dellorto parts being bandied around ebay... I'm getting more excited about pulling them apart myself.
Never worked on a carby before; but if you feel like having a go I'd spend the $160 and do it. Worste case is you muck it up and have to go 'crawling back' and it costs you $1760 - best case is it costs you $160 and you feel like a champ!
Birth... that is such a cracking point. So far I haven't found any posts saying "leave the rebuild to the pros," and like you said, if I do botch it, being $160 out isn't exactly a disaster. What's more, if I get it right, it'll free up a bigger budget for jetting/tuning (a job I am more than happy to leave to a pro) and other miscellaneous parts and repairs.
Further, most 'pros' don't care about you or their car - they are like anyone else who is at work thinking about going home and doing other things. I generally ask myself if their training / experience will offset their lathargy. In most cases I would prefer to muck stuff up for free rather than pay someone else to muck it up for me!
Funny you should say. The last carby specialist (he did nothing but carbys) I went to talked me into a big dollar rebuild of my SUs, and when the car didn't run right told me it had to be an ignition issue. I took the car to Nissco to have a look and the thing was running so rich the O2 sensor went right off the scale.
I had to go back and ask the carby guy (despite wanting to tell him go to hell) to sort out his first attempt, but not before I had dropped $400 into a completely unnecessary ignition upgrade!
 Share
    • So next year I am looking at upgrading from my VE SS bomadore ute to something more refined.  I wanted to stick with a V8 but not anything German or Australian, either a coupe or a sedan. So if I wanted anything newish that limited my options to either the Lexus RCF which I quite like. But with the price they demand and a kid on the way a 2 door coupe is probably not going to be the best idea. The next best thing would be the ISF but the newest models are 2014 and commanding over 60k and even the older 2008 models in ok condition starting around 35k is kind of bullshit. So I figured if I could not have the noise I could perhaps make do with easy power. Enter the infinity Q50 or Skyline equivalent. The price difference between the 300 and 400hp models seems a bit crazy. Right now there is 300hp Q50 one on carsales from a dealer with 61km for 27k drive away. If I wanted to get a 400hp Red or 400R car the prices seem to start at 43k From my limited research it seems that the only differences are that the 400r/Red Red runs more boost and a more aggressive tune. There are are turbine speed sensors on the turbos. Has 2 pumps for the water to air intercooler. Runs an engine oil cooler. I'm guessing that the exterior trims might look a little more sporty as well. I had a lazy look for upgrades to bridge the gap on z1motorsports They have kits that upgrade the water to air heat exchanger as well as the coolant pump which should give a non Red/400r better intercooling temps than the stock Red/400r. I added an engine oil cooler with a thermostat as well to try and make things as close as possible. Obviously the ECU is going to need a tickle. Having not done much in the way of research they also sell a ECU flashing tool with pre loaded tunes that are supposed to boost the non Red/400R by 100hp which adds 1k USD to the cost. The total cost of the parts @ the current time including shipping and taxes worked out to be $4350 AUD. Personally I would rather get the car tuned on a dyno which would probably add more cost Assuming the worst that you got a workshop to install the new parts I would guess no more than 5 hours would be required in the worst case @ 5 x $150 per hour = $750 So the total cost could be around $5100 So for easy number 5k + 27K = 32k I guess that would leave some change left over to swap out the open diff and fit a LSD Any thoughts?
    • Right, not sure why I thought it to be a lean spike. It might be fixable with modern card-style hot film MAFs which have some design features to avoid counting reversion flow but I've never tried it myself.
    • I did not realise this, I'll contribute more and earn my stripes and retry later.
    • I'm only going to hassle you for posting links to images. It's against my policy to click links that could be some nasty payload. Sadly, you need to make 9 more posts before you can just stick the images directly in a post, unless @PranK sees this and bends the rule for you.
    • Hello,new to the group, I bought a R32 from auction recently, wondering if anyone knows the cars history, seems to have the usual go fast bits on it, plan is to do an engine swap- add 2 extra cylinders and 1 extra turbo. https://www.dropbox.com/scl/fi/i4rjmlzubjbwjtguh6f4s/IMG20241011140744.jpg?rlkey=q0lumm251377vknbqktfwrycq&st=7scvwx4e&dl=0 https://www.dropbox.com/scl/fi/ro24qmwzlczzlfsr4y05x/Screenshot_2024-10-10-10-49-23-90_9a2f5bb2149dae94cd1e190effc09b33.jpg?rlkey=oyguh26ttshlf04ccp48odf4v&st=xloae97b&dl=0   New to forums and posting pics, if links don't work, take it easy on me, 42yrs old and I tune carburettors!!
