and why not registered?
I dotn wanna see someone buys it then have to wreck it cuz its not registerble under new SEV LAW :(
Yeah, what he said. If it don't have a compliance plate it will cost you about 5 grand to get it complianced before it can be registered. And that is IF it can be done.
Check this angle out before parting with any cash. It could cost you a lot more in the long run.
cecam .......i thort that they were 4 speed auto's with the 4th locking the convertor.........no auto i know of is actually overdrive...they just use a slightly lower ratio in the diff to give that impression.......but if i am wrong then i am wrong.......good to learn summin new every now and then
oh yeah...not registered...its being sold as is...but ive not looked under the bonnet yet....to see if it is complianced.....im not worried bout rego, just compliance
Even if it is complied then it will cost you a thousand to put it on road (registration plates etc)
Be very suspicous of the guy selling it as it is considerably cheaper than current market value.
Try and get him to complete an RSCV report or equivelent. It's still alot of money and if it isn't complied then forget about it
v8skylinemanmelb ,
only consider it if it has a compliance plate look elsewhere if it doesnt . if its its in good nick the price sounds good but i would prefer to pay a little more and get a turbo but thats personal opinion .
by the way these days just about all autos are overdrive ( top gear that is) , just like all manuals are as well .
Yep, your wrong, 4th is an overdrive, they achive this by driving the pinion carrier.
locking the converter gets rid of the 10% slip that occurs in a TC, so it may seem like another gear.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
