and why not registered?
I dotn wanna see someone buys it then have to wreck it cuz its not registerble under new SEV LAW :(
Yeah, what he said. If it don't have a compliance plate it will cost you about 5 grand to get it complianced before it can be registered. And that is IF it can be done.
Check this angle out before parting with any cash. It could cost you a lot more in the long run.
cecam .......i thort that they were 4 speed auto's with the 4th locking the convertor.........no auto i know of is actually overdrive...they just use a slightly lower ratio in the diff to give that impression.......but if i am wrong then i am wrong.......good to learn summin new every now and then
oh yeah...not registered...its being sold as is...but ive not looked under the bonnet yet....to see if it is complianced.....im not worried bout rego, just compliance
Even if it is complied then it will cost you a thousand to put it on road (registration plates etc)
Be very suspicous of the guy selling it as it is considerably cheaper than current market value.
Try and get him to complete an RSCV report or equivelent. It's still alot of money and if it isn't complied then forget about it
v8skylinemanmelb ,
only consider it if it has a compliance plate look elsewhere if it doesnt . if its its in good nick the price sounds good but i would prefer to pay a little more and get a turbo but thats personal opinion .
by the way these days just about all autos are overdrive ( top gear that is) , just like all manuals are as well .
Yep, your wrong, 4th is an overdrive, they achive this by driving the pinion carrier.
locking the converter gets rid of the 10% slip that occurs in a TC, so it may seem like another gear.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
