and why not registered?
I dotn wanna see someone buys it then have to wreck it cuz its not registerble under new SEV LAW :(
Yeah, what he said. If it don't have a compliance plate it will cost you about 5 grand to get it complianced before it can be registered. And that is IF it can be done.
Check this angle out before parting with any cash. It could cost you a lot more in the long run.
cecam .......i thort that they were 4 speed auto's with the 4th locking the convertor.........no auto i know of is actually overdrive...they just use a slightly lower ratio in the diff to give that impression.......but if i am wrong then i am wrong.......good to learn summin new every now and then
oh yeah...not registered...its being sold as is...but ive not looked under the bonnet yet....to see if it is complianced.....im not worried bout rego, just compliance
Even if it is complied then it will cost you a thousand to put it on road (registration plates etc)
Be very suspicous of the guy selling it as it is considerably cheaper than current market value.
Try and get him to complete an RSCV report or equivelent. It's still alot of money and if it isn't complied then forget about it
v8skylinemanmelb ,
only consider it if it has a compliance plate look elsewhere if it doesnt . if its its in good nick the price sounds good but i would prefer to pay a little more and get a turbo but thats personal opinion .
by the way these days just about all autos are overdrive ( top gear that is) , just like all manuals are as well .
Yep, your wrong, 4th is an overdrive, they achive this by driving the pinion carrier.
locking the converter gets rid of the 10% slip that occurs in a TC, so it may seem like another gear.
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
    • Well, the NA RB25 is nothing special in terms of the amount of power it makes stock, nor with any easy mods like extractors & exhaust, opening up the intake tract, etc, etc. And just like any small capacity NA engine, getting lots of power out of them takes a fair bit of money and, depending on how far you go with big cams and high compression and so on, quite grumpy to drive. So, boost is the answer. Many many many of them have had a turbo added. This is easy enough. Same as for any engine. Need the things you need to bolt on the turbo of choice, fuel system and management upgrades, clutch, stronger gearbox ( you do not want to run a boost RB25 through the NA box), diff, brakes, etc, etc, same as you would for most other NA+T things. Some much smaller number have had a supercharger added instead. These are good and cool, but have nowhere near the potential of the turbo route. All the same required upgrades apply. So, potential? Anywhere from not much to quite a lot, depending on how much effort and expense you want to go to. Is there value in the effort and expense? Objectively, no, there is not. If you're gaining enjoyment and don't mind blowing a lot of money on the project, then that's where the value is. Parts? Nissan dealers for some. Many many on-line vendors who do Japanese manufacturer spares (buy buying them from disposals at dealers around the world, direct from manufacturers, increasingly from Chinese knockoffs, etc) and warehousing them in Dubai or similar places. Amayama, Partsouk, etc etc. There are quite a few. Some local to Australia, some local to Europe, some local to the US. You can upgrade literally everything. For an NA, unless you're going to boost it, there's little point going past a nice exhaust, as I said above. After that (well, actually probably even before that) you should concentrate on making it handle the best it can, good brake components, light wheels and tyres, and just make it something to enjoy throwing through the curves. You'll never, ever win any drag races, so it needs to be taken as a nice point-to-point car. Throw in some Recaros or Brides, nice Momo wheel and gearknob, so it's pleasant to be in (because god knows, the inside of an R33 is not a pretty place!!) and away you go.
    • How many $$$ do you have to slip cams to logbook a car that鈥檚 not the orginal to the 1990 standard lol
