as above, professors do not fit onto the gtst hubs as they are too big, no most people just run them on the studs, and have no drama's, BUT is there a "converter" available? I had some custom made on my last set, but i had to destroy them to get them off to replace the rotors :nyaanyaa:
https://www.sau.com.au/forums/topic/308047-ssr-professor-sp1-centre-is-too-big/
as above, professors do not fit onto the gtst hubs as they are too big, no most people just run them on the studs, and have no drama's, BUT is there a "converter" available? I had some custom made on my last set, but i had to destroy them to get them off to replace the rotors :blink:
don't run them on the studs. good luck to those that do but remember the weight is taken on the hub not the studs, hence why dodgy spacers cause wheels to fly off now and then.
try Donnellan's or another big tyre place, i had some made up at a tyre place here in Canberra.
do you mean like hubcentric rings joeyjoejoe..?
Ive got them on my car to fit the GT-C's properly.
one of them is cracked though. when i looked for replacements i found some options on ebay (all international sellers though)
Still havent bought any... so let me know how you go.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
