hey guys been stupid and pulled the pcv out cos its failed but the seal broke off and is in the rocker cover,
my question is its a large bit but does the rb25det rocker come with a baffle so it wont fall in the the engine????????????
just wont to know so that i might be able to drive the car to work so i can pull the rocker cover off and get it out, but then is it true i have to replace the rocker cover gaskets????????
please help guys
https://www.sau.com.au/forums/topic/308052-stupid-question-please-help/
don't worry got it out wire and determination wins LOL
next question can you just block up the pcv and the out let on the plenum and not cause any problems
No, it needs to vent to some where, you could just put a little air filter on the end of it but from what i have read the car wont run the same.
from talking to many people they say cos i am running a open to air catch can being feed by both top pipe that will be enough to vent the crank case.
so blocking it off should be no problem any more.
