really clutching at straws here
does the car have any whacko-mods? plenum? throttle body? mega coil pack / injector hacks?
try unplugging the afm and see if it starts (long shot)
does the stock ECU have any signs of being tinkered with? remap stickers or crap like that?
where are you located
Im actually from NZ so duno how many people on here are from nz...i really want to find somone with a r33 like mine and see if itl start that.
Im going to try that now... and my stock ECU has a "G8" sticker on it...doesnt look like its been tinkered with...or is there any other stickers
Took the afm plug out...and no luck with it starting, i took a closer look at the ecu...its got a slight little faded strip of see through japanese symbols just under and half on the "g8" sticker... dont know what it means or if it could be from somone having played with it or even chipped it? but its so insignificant i doubt its anything to worry about it... But having a chipped ecu wouldnt cause it to not start with the pfc would it?
Oh and is it possible somthing wired up to the ignition or somthing wired up wrong is causing the power fc to not want to start?
Thanks for your help guys
nah even if it was remapped it shouldnt cause it not to start unless it had like mega large injectors and wierd AFM's
just looking for any other clues as to why it wont start
yeah if the ignition is different from standard it could certainly cause it
do you notice anythign different ? mangled turbo timer install etc ?
Yea...under my steering wheel is a huge mess of wiring...the guy that had the car before me had tapped into all kinds of ignition wires for the boost controller and gauge and turbo timer etc...and whoever did the alarm has done a shocking job...but everything works...but could the power fc be fussy about this?
yeah we have seen where the PFC won't crank over as its more fussy about wires, and the circuit etc
look in the FAQ for ECCS, there's some documentation on the ECCS system and how it needs to be setup
the assumption is your ECCS is fine, as it cranks with the stock ECU, but it might yield some clues and where to look
One of the Stagea guys is having a similar issue with his PFC,
http://www.skylinesaustralia.com/forums/Is...01#entry5093601
Is your fuel pump operating? Try a direct power feed and see if it is the same issue... Common PFC problem?
i would try the pfc in another car first, i have a pile of dead r33 PFC's here..... it is actually quite common.
I dont think mines just dead...i think its either faulty or its my car...considering the hand controller and its functions work...and well seem to be working??
yip the fuel pump is working...and its just the standard one so i havent messed around with it yet...the sensor check on the hand controller says its working right too....
Im from auckland in NZ so im trying to find somone i know with an r33 that i can try it on...
Would a shop be able to plug it into a laptop and find out the problem inside the pfc if its faulty?
This is a bit of a disaster...
Edited by R33 0wnerrr
Have you checked your plugs?
Installed a V500 in my 33 and spent hours going through the same crap as you, in the end computer was just pumping in too much fuel and fouled (drowned) the sparkies!!! A bit of trim, new plugs and then a good tune, all was good!
Really? ill check them today...hope its somthing simple like that... fingers crossed!
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
