Hi guys,
just wondering what i would need to consider in terms of setting the susp for EC?
This suggestion was made - would you or wouldnt you? what other info is vital to help?
Front
Camber 2.7-3 degrees
Toe -1.5 each side
Castor 7 degrees
Rear
Camber 1.8-2
Toe 0
Not to sure what the above will acheive, i just drive the thing :blink:
https://www.sau.com.au/forums/topic/308077-eastern-creek-susp-settings/
I would probably run more camber on the front and Toe the rear out 1 to help under brakes. But what you have would be a good start and come in after a session and measure the temps across your tyres and look for any weird wear marks, then just adjust it so you like the feel of it.
Edit: I just read your sig a 1:05 at wakie and you are asking us for ideas, your way ahead mate good luck.
I'd go 4 degrees front camber and toe the rear end in 2mm total to help with stability on corner exit as a starting point.
pyrometer from there to see if you are using all of the tyre or just one side and adjust to suit.
Edited by badhairdave
I am pretty interested in peoples responses to this question.
Can you all please post up what you have actually ended up with on your cars? And what car it is.
I am keen to get results for R32 GTsT's
Edited by Tektrader69
Maybe if you could copy, fill in your details and enjoy :domokun:
Car:
Power:
Lap time:
Tyre and Pressure:
Front Settings:
Camber:
Toe:
Castor :
Rear Settings:
Rear:
Camber:
Toe:
From speaking to others on the forums - because i will not be running a r-compound tyre, i should ease up on the front camber as the tyres wont like it.
My biggest problem is i have no idea what all the settings really mean. The local alignment fellows set the car up for wakefield last time out, so obviously when going to EC, changes need to be made because its a totally different track. I have seen some info online but find it too rich to read when it explains the terms.
My level of experience at the moment is that the only honest results i can interpret from the car is that if it has a tough time turning into corners (understeer) or when the tail end is a little skaty. Once all the other terms are used or spoken about - its a totally different language. :)
Cheers
Steve
what tyres will you be running on?
what does the car weigh?
what power does it make?
what size sway bars front and rear?
what spring rates front and rear?
what's the purpose, superlap or an enduro race?
Hi Duncan,
sorry i cant answer accurately your request but i would like to thank you in advance, not everyday you have a seasoned racer comment :)
what tyres will you be running on? 285/30/18 yoko neova ad08
what does the car weigh? ~1500kg
what power does it make? 320awkw
what size sway bars front and rear? not sure
what spring rates front and rear? the suspension i have, have a standard spring rate at F8.8R8.8 although i am not sure because it looks likes the springs have been changed
what's the purpose, superlap or an enduro race? hopefully superlap
Cheers
Steve
Hey Steve,
As previous conversations it would be best to test the car at EC with the tyre of choice and a pyrometer.
I found that street tyres don't like huge amounts of camber on my car, but then again each car is different. Spring rates/valving will also affect camber settings.
Hope it all goes well.....
ok that helps a mile!
I'm by no means a guru but this is my ideas.....
first up....road tyres (even good ones). probably ok for 1-3 laps at a high pressure. after that you would be in trouble but at superlap that's not an issue.
compared to my car you make 100kw more and weigh about the same, but you have crap (relitively) tyres. and much harder springs and same or harder bars. its a gtr, right?
so....
less camber front and much less rear. your car will slide before it rolls up on the tyre too much. and you don't want much camber on the rear because it will lead to wheelspin.
front camber 2.5o, rear camber 1.5o or even 1.0o. Maybe .25o more on the right front
castor - as much as you can get without rubbing as always. 7o is heaps in a 4wd I am surprised you could get there without issues (then again r33 is much better at the front than r32)
toe front....I run 1mm out but I think that is a personal preference. I've heard of people running between 1-3mm out per side. More will be dartier (ie feel like it turns in better) but ultimately will have less grip IMHO.
toe rear....depends how much you like the tail to move. +2mm for very stable, +1mm for normal/neutral or 0mm for unexpected mid corner oversteer (can help with mid corner understeer for a flat out lap like superlap).
pressure...what tyres? assuming falken rsr or kumho ku36 or similar I would run about 40psi hot and check how it feels. Yes it is very high but it really helps in hard tyres, especially for only a few laps.
BTW no matter what with road tyres you will rip up your outside front. If you can take a spare outside front for the weekend and change it after practice.
also...just be stable in turn 1 (ie settle it early and keep it smooth), and be very patient in turn 2 (apex is the end of the ripple strip on the exit on bad tyres). don't fall for what you see the super taxis do it wont work on road tyres
Thats a tonne of info to digest :)
the only quesiton i have, is that this wednesday i'm due to go out to EC.
With Sydney getting drenched with rain and the possiblity of it raining on this day
is very high as well. Are there any wet weather tips i should consider?
I will definately keep you all informed!
Cheers
Steve
"pressure...what tyres? assuming falken rsr or kumho ku36 or similar I would run about 40psi hot and check how it feels. Yes it is very high but it really helps in hard tyres, especially for only a few laps."
Speaking to Gordon Leven race tyres, he told me optimum pressure on the Ad08 are 36psi HOT. I will gauge this throughout the day and have a play around as well
Edited by HKS26T
OK, so in regards to rear toe, i was under the impression that toe in, say 1.5mm+ was what was recommended for rear stability...so have i mis-understood?
so....
toe rear....depends how much you like the tail to move. -2mm for very stable, -1mm for normal/neutral or 0mm for unexpected mid corner oversteer (can help with mid corner understeer for a flat out lap like superlap).
Thanks Duncan and co for the input - these settings worked a treat today on the track! You are a GURU
Besides the tyres not liking more then 2-3 laps SUPERLAP CLUBSPRINT CLASS AGO GO GO!! :(
There is alot to say about my driving - but i wish to close the gap over the next couple of months
Now i know the car can go 1:45s (unofficially) Thanks Boz! A good driver is a couple of secs off a pro :P
So what time will i run if im just average?? :D
Edited by HKS26T
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
