So I put the V35 on a weigh bridge today. Anyone want to guess the result?
It was much closer to a 350z than I expected (a 350z came with us as well).
If it helps, it was weighed with nobody in the car. I dont carry my spare wheel around, and the fuel tank was 90 - 95% full.
Also, random fact i didnt realise. My fuel tank is 60 litres. I believe the 2005 models have an 80 litre tank??
https://www.sau.com.au/forums/topic/308081-2003-v35-coupe-weight/
Brought to you by GOOGLE
Model V35 300GT V35 250GT
General Information
Layout Front-engine / RWD
Drag Coefficient [cd] 0.27
Curb Weight [lb (kg)] 3848 (1745) 3241 (1470)
Trunk Space [cu ft. (L)] NA
Overall Length [in. (mm)] 184.1 (4675)
Overall Width [in. (mm)] 68.9 (1750)
Overall Height [in. (mm)] 57.9 (1470)
Wheelbase [in. (mm)] 112.2 (2850)
Track Front [in. (mm)] 61.0 (1550)
Track Rear [in. (mm)] 59.1 (1500)
Steering Rack & Pinion, Power Assisted
Turning Radius [ft. (m)] 17 (5.3)
Tires front NA
Tires rear NA
Accomodation
Seating Capacity 5
Front Head Room [in. (mm)] 40.5 (1029)
Front Leg Room [in. (mm)] 43.9 (1115)
Rear Head Room [in. (mm)] 40.0 (1016)
Rear Leg Room [in. (mm)] 36.2 (920)
Engine
Type VQ30DD - V-6 VQ25DD - V-6
Valvetrain dohc 4-valve/cyl
Displacement [cc] 2987 NA
Bore & Stroke [mm] 93.0 x 73.3 NA
Compression Ratio 11.0:1
Redline [rpm] NA
Max. Power [bhp at rpm] 260 at 6400 215 at 6400
Max. Torque [lb-ft (Nm) at rpm] 239 (324) at 4800 200 (270) at 4400
Bhp/Liter 87 86
Mosoto, you're probably spot on.
Mine was 1,560.
The 350z weighed up at 1,520.
Anyway. Minus the 55 litres of fuel, perhaps 20 litres of other fluids, and it would be safe to say that the weight is about 1,490?
Which year z xscape ? The first gen z33 z's were the lightest, and they got heavier afterwards.
1490, but then you gotta add back in your spare, false flooring and boot trim though lol.
Mine weighed 1563kg when it came off the boat from Japan. Weighs a little less now that i have light weight pulleys :)
Basically every car that comes off the boat will only have a few litres of fuel left. Its interesting that yours was heavier than mine and i had a full tank?
I guess the scales are never too accurate.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
