So I put the V35 on a weigh bridge today. Anyone want to guess the result?
It was much closer to a 350z than I expected (a 350z came with us as well).
If it helps, it was weighed with nobody in the car. I dont carry my spare wheel around, and the fuel tank was 90 - 95% full.
Also, random fact i didnt realise. My fuel tank is 60 litres. I believe the 2005 models have an 80 litre tank??
https://www.sau.com.au/forums/topic/308081-2003-v35-coupe-weight/
Brought to you by GOOGLE
Model V35 300GT V35 250GT
General Information
Layout Front-engine / RWD
Drag Coefficient [cd] 0.27
Curb Weight [lb (kg)] 3848 (1745) 3241 (1470)
Trunk Space [cu ft. (L)] NA
Overall Length [in. (mm)] 184.1 (4675)
Overall Width [in. (mm)] 68.9 (1750)
Overall Height [in. (mm)] 57.9 (1470)
Wheelbase [in. (mm)] 112.2 (2850)
Track Front [in. (mm)] 61.0 (1550)
Track Rear [in. (mm)] 59.1 (1500)
Steering Rack & Pinion, Power Assisted
Turning Radius [ft. (m)] 17 (5.3)
Tires front NA
Tires rear NA
Accomodation
Seating Capacity 5
Front Head Room [in. (mm)] 40.5 (1029)
Front Leg Room [in. (mm)] 43.9 (1115)
Rear Head Room [in. (mm)] 40.0 (1016)
Rear Leg Room [in. (mm)] 36.2 (920)
Engine
Type VQ30DD - V-6 VQ25DD - V-6
Valvetrain dohc 4-valve/cyl
Displacement [cc] 2987 NA
Bore & Stroke [mm] 93.0 x 73.3 NA
Compression Ratio 11.0:1
Redline [rpm] NA
Max. Power [bhp at rpm] 260 at 6400 215 at 6400
Max. Torque [lb-ft (Nm) at rpm] 239 (324) at 4800 200 (270) at 4400
Bhp/Liter 87 86
Mosoto, you're probably spot on.
Mine was 1,560.
The 350z weighed up at 1,520.
Anyway. Minus the 55 litres of fuel, perhaps 20 litres of other fluids, and it would be safe to say that the weight is about 1,490?
Which year z xscape ? The first gen z33 z's were the lightest, and they got heavier afterwards.
1490, but then you gotta add back in your spare, false flooring and boot trim though lol.
Mine weighed 1563kg when it came off the boat from Japan. Weighs a little less now that i have light weight pulleys :)
Basically every car that comes off the boat will only have a few litres of fuel left. Its interesting that yours was heavier than mine and i had a full tank?
I guess the scales are never too accurate.
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
