I'm wrecking a C34 Laurel i bought in japan last November.
I have the motor package for sale in another parts sale thread, this is for the rest of the parts from the Laurel.
This is just part 1 of the parts i have for sale, the rest will be up in part 2 in the next couple of days. With more wheels, plenty of coilovers, and other good jap parts.
*Note for the mods* I am not running a business, this is all private sale stuff, just clearing out the parts i bought on a trip to Japan
Aftermarket Parts:
Wheels: 4x Work Reezax 17*8+30ish & 17*9+30ish - multi 4&5 stud - $900
Greddy Profec B Spec II Electronic Boost Controller - $400
3x Blitz Gauges – Oil Temp, Water Temp & Boost - brand new condition with senders - $600
Nismo Coilovers Front pair w/ Adjustable height & damper – to suit S14/S15/C34, complete with camber tops- $500
Cusco Coilovers Rear pair w/ adjustable height & damper – to suit S14/S15/C34 - $350
Momo Race steering wheel with momo horn button - $150
Nissan Boss Kit with alloy steering wheel spacer - $50
Recaro reclinable seat, with recaro rail to suit C34/S14/etc. - $500 with rail
Locked (welded) R200 diff - $300
Apexi ECV (exhaust shut-up flap thing) - $80
3” De-cat pipe - $50
3” cat-back exhaust to suit C34 - $150
Factory Parts:
C34 Front X-member (perfect for putting an RB straight into an S13/s14/s15 - $300
C34/s14 4 stud Front Hubs with twin spot brakes & a/m pads - $400
C34/s14 Steering rack – good condition - $150
S14/S15 tie rods & tie rod ends with rack spacers for more lock (brand new!) - $100
S14 front LCA’s - $250
C34 Rear Cradle (Non-hicas) also suits S14, etc. - $250
C34 Laurel Sideskirts (factory) - $100
https://www.sau.com.au/forums/topic/308084-wrecking-c34-laurel-drift-car/
keen on the side skirts, exhaust and full stereo surround trims etc
Is the car cut up yet? if not how much for the complete car minus the engine and trans?
The car is already cut. Body wise what i have left is passenger side guard, headlight, tail light. PM me if you're interested in any of that stuff.
No worries with the skirts & exhaust, I also have the factory rear pods for C34 which i'll throw in for an extra $50 if your interested.
I have most of the centre console trim stuff left except for shifter surround & ash tray, PM me an offer for that stuff if you like.
Couple updated pics...
C34/R32/etc Exhaust
Wheels (17*9's in front, 17*8's behind)
Cusco Rear Coilovers - s14/s15/C34
Momo "Race" Wheel + Horn
Gauges with looms & senders
Greddy Profec B Spec II boost controller (with loom, lines, & solenoid)
Steering shaft spacer
Nismo & Cusco coilover set is Sold pending payment.
Everything else still available
Check out Parts for sale Part 2: http://www.skylinesaustralia.com/forums/Ja...ee-t308235.html
Edited by Aussie sil80
Work Rezax wheels are now SOLD
Still Available:
Nissan Boss Kit - $20
  • 1 month later...
hi mate, i'm looking for some items if you keen to part it out:
1. throttle control unit
2. throttle motor
3. throttle motor sensor
4. throttle position sensor
please PM me, text / buzz me at 0420905342, or even email me: putraged@msu.edu
i really need these stuff, asap. so show me what u got.
thanks
    • So the original radiator is leaking now. Looking at getting a fully aluminium one next. Am I correct in saying that the Series 2 Auto Stageas have a separate trans cooler from factory (located in between the rad and intercooler in my previous post/message).   Currently looking at Fenix $460, Blitz $700, GReddy $800, and KoyoRad $740. What are everyones thought on Fenix ( ive read a few comments saying theyre cheap Chinese rebrands etc and how their build quality is... well.. chinese...)  compared to the others? Worth the extra couple hundies?
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
