The R34 has panel type filters in the air conditioning duct, between the fan and the evaporator.
I do have it with detailed pictures in a word doc, but it is too big for an attachment on this forum. Text only to follow...............
R34 Air Conditioning Air Filters:
SAFETY>>>>>>>>>>>All yellow wiring is related to the AirBag System. If necessary, disconnect battery before starting work
The R34 model has 2 panel-type air filters, to ensure clean air is passed through the evaporator coils. (I haven’t seen this feature on any other car before.)
Like any other filter, they also need to be cleaned, so here is some info that might make it easier next time. (It’s like brain surgery………….., easy….. when you know how.)
1. Remove the passengers-side sill trim (lever up with screwdriver, attached in 4 places)
2. Remove passengers-side kick-panel (unscrew plastic nut on firewall stud, and lever front edge off with screwdriver, attached in 2 places.)
3. Pull off rubber door sealing strip to top of dashboard.
4. Remove glovebox, by:
a. Removing the 2 lower hinge pins (by sliding inwards to unclip). Partially remove the glovebox lid, being careful not to break the tension string.
b. Remove the screw at the lower RHS of the glovebox assy, as shown below.
c. Remove 4 screws along the top edge of the glovebox.
d. Remove the screw at the lower LHS of the glovebox.
e. Disconnect the Glovebox-light cable, and remove the entire assy. The car should look like this now…
f. Remove the black spring clip on the lower edge of the white vertical filter cover, and gently lift the cover upwards.
g. Remove the 2 panel filters by sliding out the lower one first, and then the top one will fall down.
h. Remove the white fibre concertina element (dust filter), from both panels, gently clean with compressed air, then wash in hot water and detergent.
i. Remove the black honeycomb element (deodorising filter), from both panels, and very gently clean with compressed air only.
If you clean these elements carefully, they can be reused, as I would hate to think what a replacement filter would be worth.
The filters on my car were absolutely filthy…a fine specimen of the air quality in Tokyo I suppose!
Assemble parts in the reverse order, but pay particular attention to the alignment pin above the screw, on the lower RHS of the glovebox assy. See Fig 1 above.
As with all plastic parts on cars, don’t use excessive force to remove or replace them.
Hope this helps any fellow R34 owners.
Regards,
GK.
  • Like 1
https://www.sau.com.au/forums/topic/30811-r34-air-cond-air-filter-maint/
  • 2 months later...
Yeah I did all this a little while ago when installing my e-manage.....which now resides on the vent covering the A/C....I only had little bit of crap in there...probably a load of Japanese seeds :( better get the Croc Hunter and quarantine onto it...crikey!
  • 1 year later...
  • 2 months later...
  • 5 months later...
  • 1 month later...
  • 3 months later...
  • 8 months later...
    • @GTSBoy Yeah i know. The RB20 has 180Nm torque and the gearbox "should" take up to 400Nm if you are not doing stuff like drag/drift or dumping clutch and of course then it is pure "luck" on how will it last. My problem is (i think i said this in different post) that my car was very badly maintain so i would not be suprised if the oil in the gearbox was not changed until i bought it. Yeah the gearbox seem little bit sad.   @Sxnjeet the +T seem very interesting but from where iam from it was nearly "impossible" to done right and not blow twice as money as just swap for the RB25.
    • Hi, I went to the MINES shop here and bought something.. Niikura-San just happened to be there so I managed to take some pics and got him to sign my dash surround thingy. Its still wrapped in plastic back home.. I was thinking how to preserve the signature??? Im sure someones thought of this and done this in the past.
    • Perfect - thanks Joshuaho96!  Will see what I can source.
    • If the plastic wore, the paint will wear quicker. Heck, most car manufacturers cant keep the coatings they put on their buttons/trims alive these days for more than 5 years... A cheap paint won't do it!   However, you can get away with high quality vynil wrap, primarily in areas that won't cop much abuse. Skip colour matching, and just try and wrap a specific area with an edge in a new colour.   PS vynil wrapping is a prick of a job, and I suck at it, even for a small dead flat surface...
    • I think this is more a question you should ask the tuner. My assumption is you have nothing plugged into the original pin for ring gear crankshaft, which is where your map sensor should get wired to, but now you've asked the tuner to disable it. I'm assuming (because I haven't memorised your setup) you are using RB25 ECU on the RB20 loom, to plug into an RB25. You will want to check what else is connected potentially backwards between the engine, loom, and ECU. You might be all fine and safe. The best solution you could have done is wire in a map sensor, and leave the ECU able to read a map sensor.
