Hi all i got my r32 gtr and it is near impossible to keep the front windscreen fog free. The demister works quiet well but the fogging is on the outside of the window and i do beleive it is the heat of the motor fogging up the screen is there a way to adjust the bonet to help reduce this or a automotive product to stop this. It is quiet annoying.
https://www.sau.com.au/forums/topic/308111-r32-gtr-windscreen-fogging-issues/
G`day Scott,ANTI FOG made be RAIN X ,is a great Product so try see ifthat will sort your WORRIES OUT ,also what do you clear inside with look at what may as cause your worries,,GOOD LUCK,
cheer`s Chuckie.
cheers i knew about rain x just couldnt remeber the name of it lol and i dont use any products on the inside i only use a shamy and a clean lint free rag works a treat
cheer`s Chuckie.
do u wipe rain x on the inside of the glass or outside i know this may sound retarded LOL :)
RAIN X only on OUTSIDE ,ANTI FOG for INSIDE ,so good luck cheer`s Chuckie.
is it only fogging up if you have the demister on? if so, it may be that the aircon is the cause of the issue. if i drive for too long with the demister on on a cool night it actually starts to ice up the windscreen. solution is to turn the heater on and defrost it.
How would heat from the engine cause water vapour to condense on the windscreen? Surely it would help the condensed water to evaporate.
Keep the glass clean, then the water vapour has nothing to condense around.
on reason why it could be the heat from the engine is if the engine has a coolant leak and the heat is causing the coolant to boil and the resulting steam is fogging up wht windscreen. in which case, you might want to check the coolant level before you drive the car next to make sure that isn't happening
in some cases the heater-core (that has coolant running through it) (located behind the dash) can have a slow leak which puts too much moisture in the cabin
is there any other stuff in the cabin that would add moisture?
p.s. my car fogs up heaps, even this morning.. and i dont have any aircon
Edited by gfunkk
did it fog up the inside or outside?
also not having aircon can make the inside fog up in the wet, etc, especially if you have just had to run through rain to get into the car. the aircon pumps out dry air and so the moisture gets dispersed a bit as it mixes with the dry air. no aircon just pumps around moist air so the moisture just builds up
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
