Picked up a fresh import 34 GTT last week, now its in townsville, just wondering if anyone knows if the crushing humidity here (generally 75 to 95% all the time) has an effect on the performance or fuel efficiency? If so to what extent? I assume the car is made for cooler and less humid japan, hence the small intercooler so if anyone can help please do. Thanks in advance.
https://www.sau.com.au/forums/topic/308138-high-humidity-vs-turbo/
yeah its common knowledge that temperature would affect performance, humidity on the other hand i am unsure
just use good fuel and ensure the engine is in good working order
the intercooler is not on the factory setup to suit the climate, it is there to reduce heat from the intake charge from the turbocharger. the intercooler is only as a good as the ambient air temperature
Yeah i know temp is an issue, but cant figure out the humidity, the air is so thick and heavy, i know its not the same but breathing while running here is so much harder than in low humidity i thought maybe it could have a similar effect on a car.
it should be ok, i mean there isn't much you can do it about - ie you can't negate humidity
Yeah true,but i noticed in 1/4 mile time cards humidity is listed as a factor alongside temp, wind etc.
Maybe slightly worse for wind resistance or something, im out of ideas haha.
Thats why I live in Tassie. It's cold ALL the time! ha ha ha. Good crisp air is awsome for power production and throttle response.
It would be hard to know what effects humidity (if any) would have in such a warm climate.
If your worried about intake temps and humidity, throw the car on a chassis dyno in summer and give it a good work out. Then log the coolant, oil and air intake temps as well as afr's/detonation.
If your so inclined- install a larger intercooler and oil cooler with a thermostat. Also if the car is auto, invest in a trans cooler if your going to give the car a hard time.
Edited by XRATED
May try that actually, will have to wait until the end of the wet season for a cool day with lower humidity but.Yeah bigger intercooler is on the to do list lol
Try that.... moving to Tassie, Good plann! ha ha ha.
If your worried about the heat/humidity throw the car on the dyno on the hottest- most humid day you can...
Yeah I know... ha ha ha
I was stationed there for a while. PT on mondays after a sunday session is not fun in 45deg heat and 95% humidity.
Tell me about it, i still have 2 1/2 years here haha, thats what made me think about the car, it affected my performace so much i thought maybe the principal would transfer over?call me crazy
The effect of Humidity on engine performance is not worth considering.
Temperature and air pressure are the main factors that effect air density, which in turn will dictate engine performance. Every degree of temperature increase is equivalent to going up in elevation by 120 feet. A drop in pressure by 1 HPa has the effect of going up in elevation by 30 feet.
A turbo charged car is going to be less effected by pressure changes than a naturally aspirated one, because air is being forced into the manifold at greater than ambient. Temperature is the main thing that will reduce a turbo charged cars performance.
In Aviation we doing not factor Humidity into performance calculations because it is negligible.
Sounds pretty definitive, thanks mate.
Humidity does have an effect on any engine.
Those water parrticles are taking up space, oxygen space. The greater the humidity, the less air your engine has to breathe.
Why do you think a dyno needs input from humidty, inlet air temp, etc etc?
It's all compensated for in the dyno's computer package.
Give Trent or someone who does a lot of tuning a PM.
Those are the lines i was thinking along.Who is trent?
Yeah the humidity up here is very annoying, walk outside for five minutes and feels like you have walked into a shower. I notice a huge difference from day time to night time driving here, mixture of humidity and air temperature definetely has a very noticable effect.
Edited by PM-R33
Yeah i notice that too, but night here is still hot and humid like a rainy hot day anywhere else hey.now its crazy with all this rain its just getting worse.
Yeah its not the best place for enjoying a modified car. Hopefully if all goes through i should have my car out doing circuit work this year. Really worried about water and oil temps going throgh the roof though. Most of my "spirited driving" is done at night time where i never have an issue with temps, day time however is a bit of an unknown.
    • Standard GTRs are boring and there plenty of them, do what ever you want to it and just remember nothing about them is cheap anymore and if you’re picky about how you want things done it gets even worse.    if it’s an n1 or something very limited then maybe care more about it’s heritage
    • Alright guys, I've got good odds the motor survives due to a majority of spare parts. Who's taking bets on clutch, who's on transmission, and who's go diff? Happy to also take bets on if it still overheats in traffic or not 😛     Car looks amazing by the way. I've never been a fan of R34 rears, so really, I don't think any body kit etc solves that for myself, but the front end looks amazing!
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
