So, I reckon it's about time I post my little project up.
My R33 started life with me in September 2006, where it stayed with just the basics (Clutch, flywheel, FMIC, exhaust, mags, and boost). This lasted for around 10 months, before it headed to Adaptronic for an ECU install and tune... Around Oct/November of 07, I dropped a cylinder, both block and head went... This was around the time the "fail" entered...
Put forth an RB25/30, with an Ibiza of a turbo on a 6Boost split pulse manifold. This gave me all sorts of headaches, from needing a whole heap of piping etc all custom made, oil leaks, water leaks... Then a locked motor... It finally went... For 1200KM... Where it killed a head gasket... The head was ripped off, and low and behold, the motor I'd bought with an RB25 R32 head on it, turned out to be an RB20 R32 head...
Enter the new head, from R33 RB25, I had this head rebuilt, crack and pressure tested, and I put it back onto my car, along with an upgrade in injectors (880CC).
Did some mild street tuning to get it mobile, limped it from one house to another and proceeded to watch the engine bay go up in flames... Luckily the main damage was that awesome heat material stuff that "doesn't burn". I got the fire out, decided it was time to send it to the mechanics for him to do the finishing touches to tune it all up for me.
Once at the mechanics we found the oil drain had melted and split in a large way. Fixed this up, started the off boost tuning... Car developed a savage miss... And then my mechanic let the electrical smoke out and my coil packs stopped working. So out came the split fires and in went the yellow jackets.
Then the ECU decided to give us hell, which turned out that the ECU decided it no longer like the tuning software, a reflash of the ECU, an update in the tuning software, and it all went sweet as pie.
Down to the dyno tuners, part way through tuning it on the dyno (At 10PM at night) and the tuners laptop has a complete f**k out and stops working. Tuner calls his mate who owns the dyno, who luckily has EXACTLY the same laptop... Brings it down, swap harddrives (So we get the software and maps back etc). Onto tuning again...
Then the car throws the next hurdle at us... How it ramps onto boost is so savage we had to turn the gain down as much as possible on the dyno, and attempt to restrap it five times... The car keeps wheel spining and trying to climb off the dyno...
At 12:45AM in the morning, the tune is "complete" (Obviously no cold start done, and not a heap of time spent on all the idle loads etc). The final figure... 250RWKW, at around 6000RPM... Wheel spinning on the dyno.
From here, after a minor detour to find out the car lights 3rd gear up on the roll and make sure the tune was okay on the road, I get home around 1:45 - 2Am...
Climb out of bed at 5:30 AM, pick up my new Semis, meet with another SAU member and head for SAU's OP GP day... Proceed to have the SCARIEST drive of my life (First time really opening the car up) Sideways in 3rd gear under the bridge, over taking cars down the main straight wheel spinning...
The car had a few minor issues, such as an injector plug coming off causing a bad miss fire...
I made it into the 3rd session, was having an absolute ball chasing down 2 other skylines... When what happens? Oil surge... Big end bearing gone...
From here, we land the skyline with a used RB30E block, strap everything back onto it, fit a race seat and harness and head back to OPGP (On another day)... What do we find out here? We've broken a power steering pump in the first session, and the car breathes oil out the rockers... Park the car for the day after about 45 mins of driving, as it's just dropping oil (And we had a Radical doing roughly 1.08 seconds around the track there with us!). The car was also blowing alot of smoke when on boost, but this was first thought to be because of how much oil was breathing into the motor from the rockers...
Come home, do all I could to fix the breathing issue, catch cans, the works.
Head back to OP GP for one last crack at the place before it closes... Make it there, have to skip a few sessions to pull the waste gate springs, as the oil issue also appears to be a complete and utter lack of turbo oil seals... Have a ball driving the car NA and head home.
Fix up an oil drain, make up some plates to do "on the side of the road convert to N/A" and weld up a spare center and throw it in...
The car 2 weeks later heads out to Nirimba Tafe where half of SAU saw the absolute abuse that I give to my $600 RB30 motor... Flames, big bangs on the limiter, and second gear skids bashing the limiter... Whilst sliding backwards...
The motor decides it will only take all of this abuse for so long, and on the second last run developed a minor rattle... (I was having too much fun, and wanted to challenge Amy!) so I took it out for an easy run...
The car drove home, but now has a rattle which I'm yet to find out what it is...
Before the car comes back out, I'll have sussed out the rattle, fitted the new race seat for the passenger side, and added a 5 point quick release harness to the drivers seat and moved the current 4 point to the passengers seat.
As the car sits, there isn't much left of the interior from behind the front seats.
Parcel shelf gone, rear seats gone, the boot is "gone" there is about 1 or 2 trim pieces left in the boot. All sound deadening remains as I figure this isn't going to help me much... The centre console is gone, never to return, it has been replaced with a 1KG fire extinguisher.
The next mods after the passenger seat and harness will be the addition of aftermarket water temp, oil temp and oil pressure guages.
I also have some DC2 coil overs (Yeah, not much chop for racing, but for the price... They'll do)
Then comes the roll cage.
The car sits between 3 sets of tyres... My skid rims (Advan light weight RG2s), my road tyres for traversing to and from work shops on stock rims, and my semis on stock rims.
The aim of this car, was initially street... I got a taste of track work, and now the car isn't "legal" enough to drive often on the road, and as such, is only registered to get me to and from the track as I can't afford a trailer + tow car at the moment.
This car, by no means is pretty, the paint work is a mess with grease stains through it, scratches, the works. (Hey, it picked up Worst in Show at the SAU day recently!)
At the moment I'm tossing up between turning it into a proper N/A 3.0L motor and turning it high comp (As cheaply as possible), or rebuilding the current turbo (Which isn't suited to circuit work), or saving, and buying a new manifold + turbo and fitting it up.
I'd like to get into some form of racing with it, but I'll never be competitive in it... Not the cars fault, but the drivers...
Some pics:
In the beginning:
What I decided would run "well" on a 3.0L (I got it cheap with mani!)
Not long before the first install was complete (Yes it has been tidied somewhat!). See how that turbo fits so nicely?
The next day I drove to the track... And how it came home...
At Texi... The only way to do it... Staying on it...
I think I was the only one game enough to exit the Kangaroo swerve in 2nd gear under full boost... And it showed in the looks of the camera guys face as he ran for the grass
http://farm5.static.flickr.com/4058/4318042569_008af5f0b0_b.jpg
I'll grab some interior shots later, but what you'd be looking at is a stripped back section, in the front an OMP TR-S seat and an OMP 4 point harness. Passenger side S2 seats.
https://www.sau.com.au/forums/topic/308168-the-ls1-r33-of-fury/
Fatz: For what you're asking on yours, I can build 4 of mine :(
As for the turdbro, it's a bit of everything.
I do have around here somewhere EXACTLY what it is, but I'll have to find on which computer it's written down.
But the rear looks something TD07 I've been told, there's something T04R in it etc, uses the same flange as the T04Z. Is a true split pulse, and a true 6Boost split pulse mani.
Oh, and after doing some reading of a recent thread, I'm thinking of putting an oil pressure regulator on the turbo, as the turbo only smokes after a good hard rev up, IE, high oil pressure... And see what it does. If it fixes it, keep ripping skids... I'll be starting the car tomorrow to try and track down the knock knock noise too that evolved at Texi...
And Duncan, I saw that look in your eye "I wish I could treat my car like that and not worry if I broke it" :D And you know you wanted to rip a skid like it too :P
ye but mine runs has good comression and doent mind a skid and a limiter bash? without lunching its guts :)
benn doing the below for 5 years and still strong as a ox!
You call that a limiter bash? That's NOTHING! Hey Druncan?
Mine copped it all day... With flames... Then it had a nibble on something... note sure what yet... :rofl:
What's done in that motor?
yeah that would be good dunc :) do you still have my number?
And im only telling him to go NA so i can pinch his turdbro and manifold incase i ever decide to drag race the skyline like i was going to before i moved down here lol
I think I'm more adament on make this turbo work... As piss poor as it is for use in track racing... I really want to see what it can do with some boost wound in, and an extra 1000RPM...
Looking at oil pressure regs at the moment... :D
Car is about to be moved, oil dropped and inspected (With a magnet on hand as it spills from the guts of the motor.) And then I'm going to see if the noise is still there after a flush.
If it's not there, I'll be back out soon ripping epic skids. If it is, well, I suppose I'll be ripping skids with a trailer on hand... :(
And using the channels found within this club, I'll be picking up soon a 5Point quick release harness for the driver to wear, and a proper bucket seat for the passenger, whom will get the current four point harness that is on the drivers side.
And I want to get down to Wakefield soon, as I had a dream I met the owner, and he was going to close it soon as there's too many race tracks around... :)
I think that means I need to get back to the track soon... Just, I might borrow a trailer for Wakefield...
Edit: As for the RB25DE pistons... I have a block at my mums house that is an RB25DE... Might pinch the pistons and put it in another motor... Andrew, you give me naughty ideas...
And 10.8 would be PERFECT!
Okay, quick update...
Just went and fired it up... It knocks like a little bitch between 2000 and 3500RPM but ONLY when the revs are changing, hold them constant and it shuts up... :S
Edit: At this rate I'll bring you two... :)
that sounds like the oil pressure isnt coming up with revs...do you have an oil pressure guage (not the factory one) if so keep an eye on it while you rev it.
Not yet, I'm waiting for Nick to speak to his people, and get his people to contact my people, and go from there. I've got quotes at the moment for some good electrical ones at $100 a piece (For oil temp, pressure and water temp)
But I don't have a guage on hand to wack in :)
I WAS going to update my above post with some thoughts, BUT I can't edit it...
So, I'm having VERY evil thoughts after Mr Zebra decided to point out, the 25DE slugs will bump my CR right up.
Now the reason I'm thinking of turning NA, is it will make the car easier to learn to drive. IE, I'll learn to brake and corner alot better. Coupled with a 3.0L, 11:1 CR and some exhaust, and cam toying, I reckon I can get this thing to actually rocket along... Considering with the waste gate removed at Oran Park, I was still seeing speeds of ~175KM/H down the main straight, from memory Cass is only seeing around 170-180KM/H on the same straight.
So that's my 3.0L with 8.3:1 CR, on a turbo system thats building no boost and tuned cop rich at atmospheric pressure...
Now, I hear Duncan absolutely SCREAMING in agony at a GTS-t being turned NA... But keep with me.
Build this engine, 11:1 CR, nice exhaust on it, learn to drive it, setup the suspension... When I need more power, that's easy... Turbo at around 1Bar of boost...
Did a whole heap of people just scream again? But think about, cars USED to run 8:1 (And EVEN LOWER) CR for turbos... Now, a nice 9:1 and even higher is common (The MPS3 runs 9.5:1!!!) Why? Fuel has gotten better and so has tuning!
So, give it 1 - 2 years from now. Fuel such as E85, is going to be more available (Hopefully pump available), and it is allowing guys to tune RB25DETs with 20+PSI of boost PAST maximum torque in ignition... What's that telling me? More boost, or higher CR is needed... If you can screw the engine to the limit, and not ping or detonate, even on "lean" mixtures, you're not taking the fuel to the edge.
So, in 1 - 2 years, there'll be better turbos out, and I'll be able to pick one that will perfectly suit pushing even only 1 bar, on a 3L with high CR...
Now you scream "WHAT ABOUT THE FUEL SYSTEM!" well... The car is already sitting there with 880CC injectors, over kill for an N/A, but perfect for E85 and 1Bar... When I redo this engine, I'll be adding a surge tank, so it'll be a perfect time to suss out running a proper fuel cell and what pumps to run as well (Currently on an 044).
So... Thoughts people?
Proper 6-3-1 tuned manifold, 11:1 CR with the ability to later on throw a good turbo setup on and really make it haul ass?
I'm at the point where I HAVE to decide what to do with this motor and turbo...
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
