if you aren't going a massive amount of power 1000cc injectors will support over 400kw on E85. you can just use both the feed and return as feeds and run a single new return line.
as for 11:1 and bent rods if you are going to the effort of making it run 11:1 might as well throw some aftermarket rods in it as they are only ~800 for a decent spool set.
That's how I looked at the build was if I wanted 11:1 i'd need rods, which to me meant a whole motor build. At the moment everything on thi. Car has all been about bargain hunting really.
And from 1000cc to 1600cc there isn't much price difference.
I'll do some calcs late tonight if I can get my ecu to let me download it and get the dc of the 880 injectors.
At 3500 this motor feels dead as a door nail, but it's making 190 rwkw. But at 5000 rpm plus it's making 250rwkw which accelerates 5 times faster... Dyno definitely didn't read my full power read out properly... I think I'd max a 1000cc set, or at least be chewing into the safety area...
Watch this space though, big changes to setup before next texi!!! :)
  • 2 months later...
good choice on the stand. where from and what price, that is what i need.
I bought it from a local race place.
Total Race in Wollongong.
Bought $170 I paid. Probably a touch more then I needed to, but it was simply email one of the guys there and he called the moment it came in.
Titan: that's my garage... Missing a skyline... Lol
Watch this space though, big changes to setup before next texi!!! :yes:
So, I forgot to follow up on this and update everyone, at 6000 RPM and on 1bar of boost, with an afr of about 11:1, the car is using 70% of injector duty cycle on 880 cc injectors. There is no way I can even move to E85 at the moment with my current setup, and 1000cc wouldn't cut it either...
Using the old 1cc of injector = 1hp I'd be making around 600hp at the fly... Or around 450 HP at the wheels, or about 330 rwkw...
  • 1 month later...
Well, it looks like this adventure of smashed motors, and other issues from crazy horse power is coming to an end.
Another motor is going in (Still a 30) although a smaller turbo is being put on and then the car sold off.
But don't worry! The big turbo is going to another member to blow motors up with and I'll be back straight away with most likely two new beasties for some circuit work!
  • 1 month later...
So, things didn't pan out how they were planned to back in July, my white beasty is still with me, and there will be no new additions to my fleet just yet.
But what does this mean for my car?
Well, the huge turbo is GONE. Like, completely, manifold, dump turbo, GONE.
I have a new turbo sitting here (ATR43G3), which should give a super responsive setup with a very usable rev range.
I also have a new forward facing plenum.
Camber arms.
Coilovers
All to go in.
But what's happening with the motor? Well it's not 100% decided yet what products are going in, but there'll be some nice little goodies going in for a budget rebuild to handle some circuit work.
It has started! To pull the engine out, I just need to get my mate to give me a hand one night this week as well as: Under the tail shaft, and undo the gearbox cross member.
The spare motor is stripped down to a short block, I need to get some bolts to put it on the engine stand, and strip it down to nothing and send it off to be X-Rayed and machined.
Then to buy some parts to bolt it all back together!
Before it goes back in though, I WILL be cleaning every bit of the engine bay, and even doing some repainting. As you can see, I've already started, for anyone who's looked where my air filter normally goes, the chassis rail that runs beside it is normally black from grease and oil... I spent around an hour and a half stripping out those little clips that no longer hold anything, and deciding how I'm going to re-route a heap of cables through the guard to tidy stuff up!
It's beginning!
I also need to keep an eye out for a good condition front reo bar. When someone owned it before me, they appear to have had a minor bump in the front passenger side and put a minor dent in it, of which I'm not happy with! (I'm becoming a perfectionist with this car now...)
So, like, I couldn't get the motor out, as my missus isn't strong enough, not matter how hard I yell... (I KID! :))
So the motor is still in, but we started cleaning a bit more instead.
This was the start (Well, it had had a bit of a clean... The white area... )
So I scrubbed a bit...
And some more...
Stupid spots that aren't smooth panel! They don't want to come clean!
And I need to do this all over the front of the car... Both inner guards are full of oil and grease, mainly this one though from a track day issue...
Some how even more stuff fell off the front though...
So, I had some time on the weekend, and while I was looking at the car, a few things fell out...
Mainly being the front half of the tail shaft, the gearbox, my airconditioner and then some blasted Rats ran off with the wiring loom...
I was going to take out the engine, but the problem being, it appears that when the RB30E was pulled from my mates old car and stripped, the brackets for putting the chain onto appears to have been left on the head, when it went to the tip... So the engine is still in the car... :thumbsup:
It's being supported by just resting on the mounts and against the firewall.
OMG! Someone stole my dash and aircons!
Wonder how fast I'm going?
But you know what the REALLY big question is, other than what's going back in... Do I remember how it goes back together...
MAtty - use some bolts in the head where the brackets were and slip the chain over those, just make sure you have some washers big enough so the chain doesnt slip through.
I'm being very untrusting of an individual bolt... I thought of doing it... But will it really take that load?
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
