So, life decided to fill my weekends up a fair bit and I've only just been managing little minutes here and there.
I had been slowly working through the full centre panel for mounting switches, as well as a panel for mounting the fuse panel and relay holders to.
After a few CAD (Cardboarded Aided Designs), I transferred everything to real CAD, and then pushed it through CAM and spent Sunday evening with the CNC Laser cutter.
I had built a couple of months back an Acrylic Bender for this project specifically, and tonight I took the chance to bend the panel up as needed, and mock mount most of it.
Hopefully my spare time, and my body hold up on the weekend, and I'll get this actually in properly. There is two small little bits still to draw and cut for the fuse panel, but they're just as added strength for it, as well as additional mounting points for the relays.
  • Like 6
  • 1 month later...
Alright, quick update :)
Switch panel is fully mounted.
Relay/fuse panel is fully mounted.
Wiring to O2 is now run fully.
Wiring from relay to headlights is ran. Just need to run the wiring to the switch.
Indicator wiring is fully run except from the relay to the fuse (Will attempt to load the video of me quickly testing it...) First time the indicators have flashed properly in 12 years...
Power steer from Barra ECU I've found out no need to connect, as it doesn't do any controlling of varying pressure, and I don't need the PS switch feed back for the Barra ECU at all.
So far, off the top of my head for wiring to finalise it all.
Run cables for the speed sensor. But that involves me also mounting a speed sensor. Gearbox doesn't have one, and I never had ABS, so no speed rings I can use for anything. Likely end up finding an AU Falcon output housing from T5 with the speed sensor and wire that in.
Some earth straps and earth points.
run a couple of power cables from fuses to relays...
I will need to run wiring later for a thermo fan, but I'm waiting to do that for two reasons: 1) I don't know the current draw I'll have exactly, as I don't have the thermo yet, and 2) I don't have new heavy enough gauge cable if I end up with a thermo pulling 20 to 25Amp like a few of the thermo's I'm looking at do for the huge CFM they flow.
Will also be adding a horn too, but need to find my horns first. Ha ha
Two other things I will be wiring in too, but not just at this exact moment as I'm going to make up a PCB for this, but I'll be setting up wiring for the windows, and wiring for the electric mirrors.
Just about ready to move on to running the fuel lines, will need to order them up this week or the one after :)
  • Like 4
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
