As topic states:
I'd like to know if anyone has had they're standard throttle bodies enlarged on an RB26.
If so, any result data and contact details for who they used for the work would be greatly appreciated.
I havn't really seen or heard about it in Aus. I have noticed a few japanese builds have enlaged std tb's...
Cheers
Justin
PS I'm looking for constructive comments from people who have real world experience.
https://www.sau.com.au/forums/topic/308177-rb26-enlarging-std-throttle-bodies/
Getting a normal single throttle body is an expensive enough operation. I cant imagine what it would cost to have 6 throttles done at once. I think it might be easier to modify the base plate, weld and match port it to some aftermarket IDF/IDA/DRLA throttles. Injection Perfection does some really nice throttle with trumpets, which you could then build a custom plenum around. Ive seen then in 48, 50mm and larger. Extremely nice quality.
The other options are to have the throttle shafts profiled, or change to these fancy looking things.
http://www.gtr.co.uk/forum/106680-shaftles...s-rb26dett.html
I would like a set of these..but they dont seem to be available
I spoke John thismorning. He's going to try and get back into manufacturing a prototype set soon... Know one in the UK seems too interested though.
I'm not really holding my breath for a set... prices are going to be eeeexy! too.
Justin.
  • 3 months later...
Justin.
thread revival
i had mine bored to 48mm, had the shafts machined down (not quite shaftless but close), and new throttle plates installed.
cost about AU$350 in total
email [email protected] if you still want info. have pics of what we did, and contacts if sill required
cheers
ed
EFI Hardware can do them 0398735400.
i got EFI hardware to do the new throttle blades, but i had the bores milled and finished locally in syd. cost SFA altogether. can recommend EFI hardware to do this.
on the rb26 body you wont get over 48mm. maybe 48.5mm, but that would REALLY be pushing it. 48 is clearly doable though
From memory reading another thread enlarged throttle bodies are useless unless you've had a valve job port polish,as the thread said your still going to get the same amount of air passing through the intake valves.Is this true? Ive always wanted to do enlarge the Tb but not sure.
The std throttle bodies have a combined area of around the same as a single 100mm throttle body. Porting the std throttle bodies is a completely useless mod unless your making over 1000rwkw. Garunteed the ported throttle bodies are a bitch to seal and have all sorts of idle issues. I thought everybody knows not to f**k with the std throttlebodies.
really? wow, i didnt know my engine had such problems!?! thanks for the heads up, ill go remove them now
  • Like 1
Totally agree mate.
Ed your application is totally different, Rob is refering to RB26 setup.
Edited by Supa Steve
not with the 'guaranteed to not seal' part. thats a poor call. and if someone had a problem once with boring a throttle body, then the issue should be brought up with the machine shop, not solved by pissing on the idea in general for generations to come :)
also, throttle blade/bore dia is not dictated by some simple 6 45mm is X times bigger than some Z sized single. that argument is rubbish. you need to look at your port velocities and harmonics, which are a function of bore/stroke, cam timing and intake length. someone may very well need a 48mm throttle in their particular setup.
but im not here to tell someone how to build an engine. OP asked if/how you can bore the throttles. above pics demonstrate how.
cheers
ed
Edited by ed_ma61
Thanks for all the replies guys... I completely forgot about this thread.. ah ah ha
I ended up getting EFI hardware to bore my tb's out to 48mm. They sent them back to me a couple of weeks ago- they look great.
I don't forsee any idle problems.. The tb's have been machined to a much tighter tolerance than factory and hand finished. I also sent them some re-designed shaft seals that won't pop out under boost and leak. If you have stock shaft seals- they WILL leak under boost. If there is a problem with sealing, I'll send them back... I have plenty of little tricks to be employed to get a good seal too... Really it's not an issue.
It's a bit silly to say that "Garunteed the ported throttle bodies are a bitch to seal and have all sorts of idle issues"
And no I'm not chasing 1000kw.. thats silly. I'm not going into why I went with enlarged tb's as it would take all day to explain, let's just say I did some calculations, taking into consideration the projected airflow, cams, runner length and volume, plennum volume (greddy intake manifold), port size/volume, valve size, lift and engine capacity... The bigger tb's will provide some gains.
For those who have had they're tb's bored out, what gaskets or gasket material are you using? Has anyone made a phenolic gasket yet?
Cheers
Justin
Edited by XRATED
Oh and if your considering this, you won't really see any benifit unless you have a well flowing head or much larger capaicty behind them... Also a larger plenum is required to get the best from them- the stock 26 plenum is to small.
J.
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
