Awesome questions and answers in this thread.
XRATED, If you don't mind me asking (since I have a habit of asking you things), Which plenum are you using?
I am also be very interested in your quest of the perfect seal with your set up as I would imagine the response should improve, as well as higher power/torque figures.
... ha ha ha no worries mate.
As posted previously, I have a two piece Greddy RB26 plenum.
There are a few 'secret' and not so secret tricks to get tb's to seal... most are well covered in the forum.
There should be some gains... well I hope so! But more top end is not my goal.
J.
EFI Hardware can do them 0398735400.
Cheers..
Depending on price ,I might give it a go for the fun of it..i cant see how it could hinder performance at all, seems like it would aid flow if anything even if only marginally more responsive. Measuring the stock TB front is 65mm rear is 60 so there is at least 5 mill to be had plus smoothing out the butterfly has got to let it flow better than original...Doesnt it?
I have seen it done once before on a honda ,and it definately didnt make it any worse...
Ill report back with my 50kw gains later... :)
PS
Man i did a search on this the other day and nothing came up so i started a thread...fuggin..
Cheers..
PS
I did ALOT of reaserch and ALOT of calculations before I had a set of tb's modded.
If you dont have the propper head work and plenum volume mods... you will more than likely go backwards. Or best case not gain anything except a bill from EFI Hardware. Not to mention that you have to permanently modifly your injector/joining manifold and plenum runners to suit... so add another $300 for machine work and $500 for a new plenum, tb's and joining manifold when/if it dosen't work....
I recently had a conversation with a Jenvey rep... they seriously looked at producing an rb26 itb set up and manifold. They couldn't gain much anywhere in the power range OR in response/progression whith they're designs and throttle bodies.... They modelled everything on a simulation program- so nothing was actually built. The only gains they did get was with particular flow rates, with particular variables and a slight increase in tb diameter (49mm). For those who don't know who Jenvey are google it- they're one of the best multiple tb designers/manufactures in the world.
The money is better spent somwhere else... Like nitrous ah ah ah.
Cheers
Justin
Edited by XRATED
Getting a normal single throttle body is an expensive enough operation. I cant imagine what it would cost to have 6 throttles done at once. I think it might be easier to modify the base plate, weld and match port it to some aftermarket IDF/IDA/DRLA throttles. Injection Perfection does some really nice throttle with trumpets, which you could then build a custom plenum around. Ive seen then in 48, 50mm and larger. Extremely nice quality.
The other options are to have the throttle shafts profiled, or change to these fancy looking things.
http://www.gtr.co.uk/forum/106680-shaftles...s-rb26dett.html
Thatsbloodsport clip is the funniest f**kin thing ive seen in ages..
Yeah,Rang those guys, its about 250+ for my single, so f**k that..too much for too little..at half the price i may of considered it..research is good in theory, but nothing beats trying it...And ive seen people do it with ok results, But not on skylines..
J.
I think your being quite ambitious if the goal is not for more top end. I've also done alot of R&D on intake manifold design mostly on aspirated engines but I have tested varible runner length intake manifolds in turbo charged engines with good bottom end turbo responses found (upto 500rpm better spool rates). I've also been involved with the beautiful FR500 intake manifold on both 4.6L and stroke 5.4L modular V8's with various mods.
In alot of boosted applications I've never noticed any tangiable gains in upgrading to larger diameter throttle bodies. I can give you two scenerios that may surprise you:
1. HTV2300 boosted LS1 wih all the fruit - the client wanted a MAFLESS tune in order to get rid of the 78mm MAF and ultise the 90mm throttle body and intake. THe vehicle had previously made 410rwkw with the std MAF, in 4 hours of tuning I didn't see a sigle gain in horsepower at any rpm. It also didn't loose any power.
2. In some XR6T's once the exhuast and Intercooler have been upgraded along with fuel system the vehicles have a tendance to over boost due to the 32mm wastegate port. In these situations I reduce the throttle opening to control the boost. I can tell you that in some situations I have remduced throttle openings to 40% total opening without any loss in horsepower and this is up around the 360rwkw mark with the std(72mm??) throttle body.
I dont know your current setup but a change in runner length may warrant more gain in response and midrange power without a loss in topend power. Note that I'm not discrediting proper port matching as ruducing turbulance in the port can really help.
  • 1 year later...
  • 4 years later...
Sorry to hear bud. Hopefully karma gets the assholes.
I'm looking at getting my set enlarged soon too. Is there anyone other than efi hardware able o get this done for cheaper? Over $800 with postage each way send a bit steep.
  • 7 months later...
37 minutes ago, eXquiSit said:
Tbh it would be cool if hypertune or plazmaman made larger billet throttles then also one of their plenums to suit the larger throttles
I would buy that!
  • Like 1
  • 4 weeks later...
  • 2 months later...
  • 7 years later...
bump.
Anyone had this done? either 49 or 50mm? Been pondering what to do while mines in storage. Been thinking of DBW but if I do that, then might as well do this too. Want to retain 6 throttles.
I have a fully build head(CNC, OS valves, 286/278 cams, etc etc still running squish), and a Greddy old school intake with port matching.
Head bench flowed 300cfm. Wondering whether bigger throttles will give me any gains. Makes 563kw.
30 minutes ago, Predator1 said:
bump.
https://www.gtrusablog.com/2020/03/itb-vs-single-throttle-individual.html
 From the math here and some real world dyno comparisons against a 102mm throttle I doubt it’s worth the effort and expense.
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
    • I agree, and yet my "HRM " hat is also on, as his wideband is in disagreement with the narrowband where they used to play closer attention to each other.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
