Awesome questions and answers in this thread.
XRATED, If you don't mind me asking (since I have a habit of asking you things), Which plenum are you using?
I am also be very interested in your quest of the perfect seal with your set up as I would imagine the response should improve, as well as higher power/torque figures.
... ha ha ha no worries mate.
As posted previously, I have a two piece Greddy RB26 plenum.
There are a few 'secret' and not so secret tricks to get tb's to seal... most are well covered in the forum.
There should be some gains... well I hope so! But more top end is not my goal.
J.
EFI Hardware can do them 0398735400.
Cheers..
Depending on price ,I might give it a go for the fun of it..i cant see how it could hinder performance at all, seems like it would aid flow if anything even if only marginally more responsive. Measuring the stock TB front is 65mm rear is 60 so there is at least 5 mill to be had plus smoothing out the butterfly has got to let it flow better than original...Doesnt it?
I have seen it done once before on a honda ,and it definately didnt make it any worse...
Ill report back with my 50kw gains later... :)
PS
Man i did a search on this the other day and nothing came up so i started a thread...fuggin..
Cheers..
PS
I did ALOT of reaserch and ALOT of calculations before I had a set of tb's modded.
If you dont have the propper head work and plenum volume mods... you will more than likely go backwards. Or best case not gain anything except a bill from EFI Hardware. Not to mention that you have to permanently modifly your injector/joining manifold and plenum runners to suit... so add another $300 for machine work and $500 for a new plenum, tb's and joining manifold when/if it dosen't work....
I recently had a conversation with a Jenvey rep... they seriously looked at producing an rb26 itb set up and manifold. They couldn't gain much anywhere in the power range OR in response/progression whith they're designs and throttle bodies.... They modelled everything on a simulation program- so nothing was actually built. The only gains they did get was with particular flow rates, with particular variables and a slight increase in tb diameter (49mm). For those who don't know who Jenvey are google it- they're one of the best multiple tb designers/manufactures in the world.
The money is better spent somwhere else... Like nitrous ah ah ah.
Cheers
Justin
Edited by XRATED
Getting a normal single throttle body is an expensive enough operation. I cant imagine what it would cost to have 6 throttles done at once. I think it might be easier to modify the base plate, weld and match port it to some aftermarket IDF/IDA/DRLA throttles. Injection Perfection does some really nice throttle with trumpets, which you could then build a custom plenum around. Ive seen then in 48, 50mm and larger. Extremely nice quality.
The other options are to have the throttle shafts profiled, or change to these fancy looking things.
http://www.gtr.co.uk/forum/106680-shaftles...s-rb26dett.html
Thatsbloodsport clip is the funniest f**kin thing ive seen in ages..
Yeah,Rang those guys, its about 250+ for my single, so f**k that..too much for too little..at half the price i may of considered it..research is good in theory, but nothing beats trying it...And ive seen people do it with ok results, But not on skylines..
J.
I think your being quite ambitious if the goal is not for more top end. I've also done alot of R&D on intake manifold design mostly on aspirated engines but I have tested varible runner length intake manifolds in turbo charged engines with good bottom end turbo responses found (upto 500rpm better spool rates). I've also been involved with the beautiful FR500 intake manifold on both 4.6L and stroke 5.4L modular V8's with various mods.
In alot of boosted applications I've never noticed any tangiable gains in upgrading to larger diameter throttle bodies. I can give you two scenerios that may surprise you:
1. HTV2300 boosted LS1 wih all the fruit - the client wanted a MAFLESS tune in order to get rid of the 78mm MAF and ultise the 90mm throttle body and intake. THe vehicle had previously made 410rwkw with the std MAF, in 4 hours of tuning I didn't see a sigle gain in horsepower at any rpm. It also didn't loose any power.
2. In some XR6T's once the exhuast and Intercooler have been upgraded along with fuel system the vehicles have a tendance to over boost due to the 32mm wastegate port. In these situations I reduce the throttle opening to control the boost. I can tell you that in some situations I have remduced throttle openings to 40% total opening without any loss in horsepower and this is up around the 360rwkw mark with the std(72mm??) throttle body.
I dont know your current setup but a change in runner length may warrant more gain in response and midrange power without a loss in topend power. Note that I'm not discrediting proper port matching as ruducing turbulance in the port can really help.
  • 1 year later...
  • 4 years later...
Sorry to hear bud. Hopefully karma gets the assholes.
I'm looking at getting my set enlarged soon too. Is there anyone other than efi hardware able o get this done for cheaper? Over $800 with postage each way send a bit steep.
  • 7 months later...
37 minutes ago, eXquiSit said:
Tbh it would be cool if hypertune or plazmaman made larger billet throttles then also one of their plenums to suit the larger throttles
I would buy that!
  • Like 1
  • 4 weeks later...
  • 2 months later...
  • 7 years later...
bump.
Anyone had this done? either 49 or 50mm? Been pondering what to do while mines in storage. Been thinking of DBW but if I do that, then might as well do this too. Want to retain 6 throttles.
I have a fully build head(CNC, OS valves, 286/278 cams, etc etc still running squish), and a Greddy old school intake with port matching.
Head bench flowed 300cfm. Wondering whether bigger throttles will give me any gains. Makes 563kw.
30 minutes ago, Predator1 said:
bump.
https://www.gtrusablog.com/2020/03/itb-vs-single-throttle-individual.html
 From the math here and some real world dyno comparisons against a 102mm throttle I doubt it’s worth the effort and expense.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
