So I've spent the last day and a half trying to install an FMIC into my GTt r34 Skyline.
I've ran into a few problems, and ended up just putting the stocky back in so I can drive it.
Mounted the cooler no problem, had to get a new smaller thermal fan and move the horn, but all good.
Taking out the old side-mount was a bit of a hassle, but got it, and the piping on that side fits perfectly.
My problem is with the piping on the drivers side.
First, we managed to find a gap small enough to JUST fit the piping through. But coming up into the engine bay, and running across above the radiator fan, it sticks up too much and the bonnet cant close (aswell as having to remove the engine cover).
Can anyone who has installed an r34 fmic give me any ideas? I'm getting quite frustrated!
Cheers.
PS Will post pics if needed...
https://www.sau.com.au/forums/topic/308202-installing-r34-fmicplease-help/
What brand of FMIC is it?
It's just a crappy brand one (chinese I think :-S)...Monsta Performance.
Piping kit is nothing like what it needs to be, but I have some extra piping to work with.
Just need to know where to put it and how it should go in :)
Most of the FMIC apart from the turnflow units require you to cut a neat hole under the battery box in the same place as the GTR has one.
If it is the following item then from the pics it will need a hole cut.
Link
Link
Cheers mate.
Any chance of pics of where the piping comes up from the cooler into the engine bay? And how it goes over the engine bay to connect it?
Much appreciated :(
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
