This is Part 2 of a big parts sale. Check out Part 1 of this sale here
Also check out my RB25 manual engine package (front cut) for sale here
All prices are negotiable, inspections are welcome. I'm located ~15 minutes south of the Adelaide CBD.
18" Dished Mesh wheels 4&5 stud - 18x9 +27 fronts, 18x10 +15 rears. Tyres: 225/40 Bridgestone G-Grids front, 265/35 Dunlop Lemans rear - $1800
post-7016-12661470497695_thumb.jpgpost-7016-12661471209188_thumb.jpgpost-7016-12661471446222_thumb.jpg
Ohlins coilovers "Mines edition?" full set for R33 GTR 10k/10k - no leaks, no knocks, etc - $1000
HKS "Hyper D" full set for S13 8k/6k rates - no leaks, no knocks, etc - $1000
post-7016-12661462704375_thumb.jpgpost-7016-12661462950858_thumb.jpgpost-7016-12661463802409_thumb.jpg
Tein HE "Winding Master" pair fronts for S13 - no leaks, no knocks, etc - $500
Bride Brix "Keiichi Tsuchiya Model" Limited Edition. With S13 drivers-side bride rail - $450
post-7016-12661467713036_thumb.jpgpost-7016-1266146808366_thumb.jpgpost-7016-12661468361611_thumb.jpg
Greddy Temp Gauge with warning light & memory recall - silver face - complete with loom, senders & control box. - $150
Momo wheel - $80
Panasonic jap double-din CD/MD head unit - $50
Trust/GREX White gearknob suit Nissan - $40
sweet. will you post?
or i am coming to adelaide in april. more then happy to pay a deposit to hold and pick them up when im up there.
  • 1 month later...
Lots has sold since last update
Still for sale.
4 Stud S13 Front Hubs - $150
twin spot nissan brake callipers on vented 4 stud 280mm disks, with aftermarket pads - $200
S14 Lower Control Arms - $2500
Momo Race steering wheel with momo horn button - $100
Recaro reclinable seat, with recaro rail to suit C34/S14/etc. - $400
Ohlins coilovers - R33 GTR - $1000 (sold pending payment)
Momo race steering wheel (another) - $60
Locked R200 diff - $200
3” De-cat pipe - $50
S14/S15 tie rods & tie rod ends with rack spacers for more lock (brand new!) - $80
C34 Rear Cradle (Non-hicas) also suits S14, etc. - $250
C34 Laurel Sideskirts (factory) - $100
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
