Jap Parts Sale #2 - More Wheels, Bride Seat, Coilovers, Etc
This is Part 2 of a big parts sale. Check out Part 1 of this sale here
Also check out my RB25 manual engine package (front cut) for sale here
All prices are negotiable, inspections are welcome. I'm located ~15 minutes south of the Adelaide CBD.
18" Dished Mesh wheels 4&5 stud - 18x9 +27 fronts, 18x10 +15 rears. Tyres: 225/40 Bridgestone G-Grids front, 265/35 Dunlop Lemans rear - $1800
post-7016-12661470497695_thumb.jpgpost-7016-12661471209188_thumb.jpgpost-7016-12661471446222_thumb.jpg
Ohlins coilovers "Mines edition?" full set for R33 GTR 10k/10k - no leaks, no knocks, etc - $1000
HKS "Hyper D" full set for S13 8k/6k rates - no leaks, no knocks, etc - $1000
post-7016-12661462704375_thumb.jpgpost-7016-12661462950858_thumb.jpgpost-7016-12661463802409_thumb.jpg
Tein HE "Winding Master" pair fronts for S13 - no leaks, no knocks, etc - $500
Bride Brix "Keiichi Tsuchiya Model" Limited Edition. With S13 drivers-side bride rail - $450
post-7016-12661467713036_thumb.jpgpost-7016-1266146808366_thumb.jpgpost-7016-12661468361611_thumb.jpg
Greddy Temp Gauge with warning light & memory recall - silver face - complete with loom, senders & control box. - $150
Momo wheel - $80
Panasonic jap double-din CD/MD head unit - $50
Trust/GREX White gearknob suit Nissan - $40
  • 1 month later...
Lots has sold since last update
Still for sale.
4 Stud S13 Front Hubs - $150
twin spot nissan brake callipers on vented 4 stud 280mm disks, with aftermarket pads - $200
S14 Lower Control Arms - $2500
Momo Race steering wheel with momo horn button - $100
Recaro reclinable seat, with recaro rail to suit C34/S14/etc. - $400
Ohlins coilovers - R33 GTR - $1000 (sold pending payment)
Momo race steering wheel (another) - $60
Locked R200 diff - $200
3” De-cat pipe - $50
S14/S15 tie rods & tie rod ends with rack spacers for more lock (brand new!) - $80
C34 Rear Cradle (Non-hicas) also suits S14, etc. - $250
C34 Laurel Sideskirts (factory) - $100
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
