Lol. jeez learn sumfing new every day. Theres more to it than just the fog lights, though. I kinda changed the shape of the headlight, and added a few things to to front bar (u can see them on the sides). Yeah i know it is one of the sexiest bumpers in the world. Which is kinda why it took me an hour to decide to do a minor adjustment (on the side). then i gave up, lol, coz i figured i would wreck it. but yeah. worth a try anyway.
Anyone kno where i could get sum 3D design ware? thinking of making a new car. I drew a few in paint, and ill post dem later. but yeah. thanks for the feedback.
hey that bumper mod on the side is shmick, its so nautral you can't notice it (an I didn't I admit). well done.
As for MS Paint work... WOW... pixel art is teh bomb... hehe... but last one looks shite. and convince ur gf to buy a skyline lol so u can do pixel art of them.
Yeah i do sketch. Sketched so many cars, kinda lost count. Kinda a passion. but wat sucks is dat i dont have a portfolio, which doesnt allow me to do 'my' perfect double degree, that is Engineering (mechanical)/Design (Industrial Design). Really pissed me off, coz i realised i needed one after the deadline. And i know i wouldve got into it. so i didcked myself. heh. If i can get the scanner to work (or just get a new one), ill post up my sketches.
  • 8 months later...
here are some pics i managed to scan from my lecture notes book, and my uni diary. tell me what u think.
and if anyone can get rid of the lines for me that would be great. of course you dont have to coz i dont really have a need for them to be romoved. anyhew here they are;
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
