Hey guys,
Today I had a crack at re-spraying painting my stock front bar and it came up pretty good with one exception; its really dull!
Colour is near perfect match (which is good considering my car is a 4-layer pearl). The reason for the dullness I suspect is because my paint surface is really rough, whereas my car is really smooth.
How do I go about correcting this? I've got 1600 grit sand paper which I've used to remove most of the roughness, do I not just cut and polish, or have a missed a step of sanding somewhere along the process?
Thanks,
Kieran.
https://www.sau.com.au/forums/topic/308316-diy-spray-job/
The dulness can be from a few factors, one it could be the technique in whcih you sprayed, have you used a clear finish? You shouldnt sand it down now after your final top coat but just cut and polish it , you should of just sanded it with a fine grit after the primer coat. Also it could be the mixing of paint and thinner could have been wrong which is why you got dullness but usually with arcylic laquer when after you cut and polish it you will get the shine and it will make it a smooth finsh
https://www.sau.com.au/forums/topic/308316-diy-spray-job/#findComment-5088668
That's what I did wrong, I didn't sand after the primer. I'll give it a cut and polish and hope for the best. Not really worried about overall quality. I have the equipment now, materials are cheap. Just need the experience!
Thanks for the quick reply.
https://www.sau.com.au/forums/topic/308316-diy-spray-job/#findComment-5088680
cut and polish by hand will take quite a while.. did my bonnet on my old car and my arm was sore the next day LOL..
i would give a bit of wet and dry rub over first.. using wet to smooth it out first.. wash down and then cut and polish..
https://www.sau.com.au/forums/topic/308316-diy-spray-job/#findComment-5089601
if you want a really good shine you need to lightly sand it between coats as well as giving it a good polish after the clear.
pretty sure you cant knock-off metallics - that would only work with solids and clears
https://www.sau.com.au/forums/topic/308316-diy-spray-job/#findComment-5090774
So cut and polish just slowly removes the paint, correct?
Could I cut and polish till its thoroughly smooth then respray it with the finisher again, or just put some wax on it?
Excuse my noobishness, I had the gear lying around for so long and didn't use it because I was paranoid of screwing it up. Then a day came along with perfect weather and I figured I'd just give it a crack. If I stuffed it up I'd seek help, turns out its a lot easier than expected!
Highly recommend it to anyone considering doing it themselves, I am the least practical, mechanical or "hands on" guy you'll ever meet, yet I found this surprisingly easy and very satisfying!
https://www.sau.com.au/forums/topic/308316-diy-spray-job/#findComment-5090865
don't respray unless you cut through the clearcoat. you are cutting and polishing the clear to make it as smooth (and as a result, glossy) as possible. if you go over it again with the same method as before after that with the paint gun, chances are it will look like it did before.
https://www.sau.com.au/forums/topic/308316-diy-spray-job/#findComment-5091102
just out of curiousity, were you using acrylic or 2 pack? and what sort of ratio did you mix the paint and the thinners and the clear and thinners? this may have a bit of an effect on the results. if you have a lot of 'orange peel' happening then the clear won't look as nice.
also just remembered this from when i was first looking at doing some painting. it is well worth a read for anyone thinking about doing it.
http://autofix.com.au/blog/archives/497#comment-75099
https://www.sau.com.au/forums/topic/308316-diy-spray-job/#findComment-5092082
It was acrylic, I had to put a yellow layer down then follow it up with a sort of silvery, clear paint that make it sparkle a bit more. I did an even 50/50 ratio of paint to thinner on the yellow paint, and then 3:2 ratio for the thinner:silvery paint and the thinner:top coat. This what the shop recommended, and was written on the paint tins.
Edit: Thanks for the link too, I actually found this when I was painting the other day. Very helpful.
https://www.sau.com.au/forums/topic/308316-diy-spray-job/#findComment-5092465
here is the crutch of your problem
"Acrylic Lacquer Con’s
Has to be ‘buffed’ and polished to achieve a good shine.
Is not as chip and scratch resistant as 2 Pack.
2 Pack Pro’s
Has a shine straight off the gun, great for areas that are hard to polish such as engine bays and door jambs.
Is very hard and scratch/chip resistant once set."
2k acrylic doesnt need to be buffed to have a full gloss, regular acrylic does. get out your 2000grit paper and get smoothing - then buff it out - you could try the meguirs buffing kit - comes with the electric orbital buffer etc and i dont think its too expensive.
https://www.sau.com.au/forums/topic/308316-diy-spray-job/#findComment-5092820
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
