I have done quite a bit of searching on here and didn't come up with any explanations on how it was done, and whether it was easy or worth it compared to strengthening the standard 5 speed.
So if anyone has done it, or had it done by a workshop let me know.
I am in the situation where it looks like my 5 speed has some internal problem, whilst driving at or over 100km/h if i let my foot off the throttle there is a horrible rattle sound from the gearbox area, strange thing there is no noise when i have my foot on the throttle. The noise gets worse as speed increases..
I dont want to buy a second hand 5 or 6 speed, i prefer to buy new unless a very low KM box can be sourced.
Any info would be appreciated, thanks
Shaun
https://www.sau.com.au/forums/topic/308331-r32-gtr-6-speed-conversion-getrag/
Yeah that's fair enough, if im to stay with a 5 speed im likely to buy one new, thats why i was thinking along the lines of a 6 speed conversion as a second hand one is only a few hundred more than a new 5 speed, there's also the choice of PPG gears for the 5 speed which is another option, I believe the 6 speed is the better option IF it isn't ridiculously difficult. Living 350km from melb doesn't make it easy to leave your car at a mechanic for a week or two..
Has anyone done the conversion of the 6 speed? Would love to hear the benifits of this conversion as to say a upgraded gear set/ dog box. Wouldn't the extra gear mean a close ratio gear set is more than likely while still maintaining daily driving and better acceleration?
IIRC the diff ratios are different in R34s, so you might want to change the diffs as well if you're doing the gearbox. I guess if you're changing the gearset ratios you could choose one that will work with non-R34 diffs.
Justjap used to sell new boxes for $3200. Maybe they still do.
You will need:
New clutch- and or push pull converter. 33 and 34 GTR clutches are pull, 32 is push.
Box- expensive for it's strenght. A 34 6 speed is debatable after 550 odd hp for racing.
Modified drive shaft/s
Modified g-box mounts
34 diffs or similar ratios
Adapt the 32 ATESSA actuator, to the 34 transfer case.
Adapt the speedo drive
OR
Get your old box built to new, with a nice OS gear set and twin syncro's.
Hope that helps
J.
Edited by XRATED
Thanks Xrated been looking for that sort of info for ages lol. what about if you put a gear set in a getrag box? would it be better for acceleration, fuel ecconomy and top speed? want something that is going to be tough but hopefully still a little street friendly. Not exactly the easiest thing to do but i had a mate with a dog box in a 33 gts type m making 850hp at the wheels but was still ok to drive on the street. It was a six speed. Would ask him but i no longer have contact :D so regreting not asking sooner lol
Cheers
Cheers
They're obviously stronger with a gear set. There are a few different options. Honestly I dont see there being much acceleration advantage with 6 gears, unless you have custom ratios. Fuel economy???? dude, it's a GTR... Top speed... how fast do you want to go? I did 312kph with my 5 speed PPG box and it had more in it (It was scary!).
I have a 1-4 helical cut PPG gog box. It's quiet and I find it easy to use (used to drive professionally) and 5th is standard- cyncro and ratio. 1-4th ratios are different ratios. But if you do big miles, go for the PPG cyncro gear set.... better 1-4th ratios for acceleration, standerd 5th gear for highway driving and will take plenty of HP.
Honestly a 34 6 speed conversion is alot of money for the result.
J.
  • 6 months later...
You will need:
OR
Hope that helps
J.
Sorry to revive an old thread but me and another mate were thinking about this the other day.
Why would you have to change the diff ratios?
I mean leaving the 4.1s in the 32 would mean that you would have the top end of the standard 32 gtr with the close gear set down low
allowing you to keep the engine/turbos better within there range.
I would have thought that this would have been better than just having a close gearset 5 speed. Especially if its still going to be a daily driver.
Sorry if this is a dumb question and i've missed something lol
Cheers Matt
Cheers Matt
You are right. There have been a few R34 GTRs here change their diffs for R33 4.1 diffs.
  • 9 months later...
I found the Nismo Getrag transmission conversion http://www.nengun.com/nismo/getrag-transmission-conversion-kit
Its too pricey to buy new unless your building a show car, but it seems it is quite easy to do.
Use an R34 gearbox, transfer case, front prop shaft, transmission cross-member, transmission mount, and clutch.
Then for the rear prop shaft use the front section off an R34, and the rear section from an R32.
The transmission tunnel needs hammering for clearance on both sides, only about 10mm either side, not a big deal in my opinion.
Im thinking it could be done for 6-7 grand depending on the cost of the gearbox second hand.
2nd hand boxes seem to get roughly 4500 give/take.
Certainly costly, also need the diffs too as ratios are totally different. So that adds cost as they are hard to get as well.
Id say k would be bare minimum and likely quite a bit more.
More than a OS gearset replacement by a good 3k. Given people like Piggaz, Lee wah etc have proven 400rwkw & big launches is no problem for the gearsets, probably the better choice.
Be interesting to see how much a getrag would hold without blowing apart. Not aware of anyone going above 400-420rwkw. And none of those guys were doing big launches etc.
Apparently the 4.1 diff is fine, first gear is just very fast. I don't understand why people break the getrag if it has the same gears as the Supra which is known to handle 800hp with slicks on a drag track (no wheelspin). Im willing to do something different and it could transfer the car into a better machine. My brother has just put a 6 speed in his 5 speed WRX and it feels 200% better because of the close ratio gears. Much easier to drive on the street and feels heaps livelier. Another option for me to think about i guess, lucky i don't rely on the GTR every day :)
A WRX is not a good example. They are a lowdown punch motor.
You need the extra length of gearing IMO for a 350-400rwkw 2.6ltr.
The OS box has a longer first (over stock) by about 12-15km/h IIRC. Might not sound like much on the screen but on the street it makes quite a difference indeed, very noticeable when his car is still powering in gear, pulling ahead whilst you look to grab another gear :(
Chopping it backwards would make it very hard to deal with and not generate much load potentially. Without load you ain't going to decrease boost response etc.
With 4.1/getrag compared to a 33 box with O/S gears. You will have almost shifted 1.7 times before the OS box has shifted once.
Shifting = time wasted.
But whatever dude, your money :)
You raise valid points, I have noticed the GTR's have very poor response under 3,000rpm compared to a 2.0L WRX, I don't see why that is though? I plan on rebuilding my motor with a 2.8L stroker kit in future, the extra cubes along with other mods should help with torque.
im right in the middle of this debate also. i can't decide between a getrag or a full dog box. seeing as i will use my gtr for 99% circuit use, im leaning toward a 6spd but in the back of my mind the safety of billet gears may persuade me... i think my power level will require a dog box too.
hmmmm.........wat to do!! lol *slaps forrid
In your situation i would definitely go a rebuilt 5 speed, my car will be 99% street use and an extra gear is nice and won't hurt performance as its a street car. Im going to be sticking with the 5 speed, the potential for future hassles just isn't worth it for me.
With full on track work with fast shifting the syncros in the Getrag won't last.... gears will last forever but syncros won't. I picked up the whole kit to fit R32/R33, shatfs, cross member, shifter and including Nismo Twin Coppermix clutch with flywheel. Intended to go in my R33 GTR but selling car now :(
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
