Hey guys,
The other day my mate and I decided to take a few shots at the Glen.
When I say mate and I, I mean I just drove and he did all the photography :P
Thought I'd just share them with you guys, let me know what you think :)
Heres a link to his facebook group that he has started up, join up if you want to ask him any questions or ask about getting your car done :)
http://www.facebook.com/group.php?gid=3025...3262&ref=ts
Cheers, Leigh
https://www.sau.com.au/forums/topic/308343-a-few-photos-of-my-r33/
lol more low! i already scrape everywhere.. pain in the ass to be honest :thumbsup: back is a little higher then usual with no sub / jack / tyre atm :P
edit: if theres someone reading this and getting there Ps soon (few months) and want a nice, clean reliable n/a 33 123rwkw shoot me a pm.
nah believe me i do.. not sure why it looks a little high in a few shots, its like a little over 100mm (had to get it tested) and have a small crack from going 1km/h sideways up a driveway was a little steep but had to go up it >< so gay.
After owning a body kit i wont be doing it again, too much of a pain (mainly the front fiberglass is like :@) when I get GTR i'll just be leaving it as is body wise :thumbsup:
I like the 2nd last shot with the reflection.
Also the pole has cast a shadow at the back of the car :)
Anyways nice pics there. Keep it up :)
oh and you scrape with that height???? no way..
thanks for all the good and comments guys :) and the constructive criticism is good as well :)
I also love the 2nd last shot :)
I dont know why people dont think i wouldn't scrape lol :) got a crack in the front bar from it, its gay :( not as low as some members cars here im sure :rofl: next car ill just be lowering it a lot suspension wise and keeping the body stock :) even going so slow up a driveway and the stupid fiberglass cracked on me, no biggy just going to bog it up and sand it down a little and just use some touch-up on it i've just been to lazy to do it lately haha
Haha I took the stock spoiler off and wacked that little lip on :cool: its all down to personal preference i guess.
Thanks for all the great comments, will pass these on to the photographer.
Going to be sad to see this car go also.. but then again a upgrade to GTR will be well worth it.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
