Lost track of my other thread. Price drops on EVERYTHING and prices are final. CHEAP AS IT IS. Need to clear shed of these dust collectors.
Parts list and prices
Suspension----------------
Whiteline Rear Upper Control Control Arm Bushes BRAND NEW W0579, $45 Fits r32, r33, r34, 180sx, ceferio, etc
Whiteline Rear control arm caster adj. bushes BRAND NEW, don't know wth they fit, found them in my box of bushes one day lol part number is KCA337. $45
R32 GTS4, R33 GTS4, Stagea Front swaybar $20
R32 GTS4, R33 GTS4, Stagea Rear swaybar $20
R33 GTS4 stock shocks w/ aftermarket springs, Shocks are in ok condition, no signs of leaks. As for springs there in good condition just not 100% which brands they are, being red, either pedders, nismo or apexi springs?. They might be pedders but I can't tell. Fits R32 GTS4, R33 GTS4, GTS(25), GTST. $180
R33 GTR Front 5 Stud Hub Assembly perfect for 5stud conversions for GTS4s $140
Interiors--------------
R33 GTR Centre Console compartment (compartment bit behind gear boot). Excellent condition, no damages. $40
R33 Interior Front panels Great condition, no marks, no scratches, no tears $60
OR $100 for all 4
R33 Interior Rear panels Great condition, no marks, no scratches, no tears. $60
R33 Climate control unit. In good working order no damage. $50
R33 Front Seat Belt sets, Good condition was working perfect when removed. $80
OR $140 for BOTH
R33 Rear Seat Belt sets, Good condition was working perfect when removed. $80
Engine----------------
R33 Series 2 VCT N/A Motor RB25DE 147kw, 114,000kms motor is in A1 condition, regularly serviced synthetic oils. Only pulled out for turbo conversion. Includes 4WD Sump and Front Diff and shaft, wiring loom and ecu iridium plugs, exhaust manifold and intake pipe. Can also be used in RWD application, just swap sump with a RWD sump.
NOTE: Front end parts have been taken off as I needed them. These included, water pump, tensioner and idle bearings, harmonic balancer, A/C and pwr/steer pump, pretty much 100,000km kit as well as cam covers, cam gears and CAS. Thats it.
$450. If dosen't get sold for right price I will be keeping it for a project.
Drift Urethane Pod filter Blue + heat shield, Still in excellent condition $20
Unknown Pod filter w/ RB25 AFM adapter. $10
Gates Timing belt used 10,000kms only $40
RB20/RB25 Crossover pipe in good condition - $20
R33 Series 2 GTS4 4WD Gearbox will fit stageas as well as any other running 4wd gear including GTRs. 114,000kms in good working condition, however 4th started to slightly crunch after I had oil changed too thin, needs thicker oil and should be ok.
$390. Will be keep as a spare if not sold for right price.
Stainless steel Cannon Muffler Angle Cut Tip - 2.5'' Inlet, 5.5'' Barrel, 4.5'' Angle cut Tip
Very good condition no dents, came off R33 $35
PICS WILL BE UP VERY SOON!
Contact 0412 297 325 Located in Sydney will post at buyers expense.
Thanks
Edited by OoskylineoO
  • Replies 53
Steering wheels gone, never listed it in the list. Should have crossed it out in the picture lol sorry guys.
Does the steering wheel have a boss kit? Hicas compat? $$? Seperate the handbrake boot from the console?
If you really want I can take it off for ya.
Sounds good man, how much you want for it inc postage to adelaide?
NEW PARTS AND LIST UPDATE
Hurricane High Flow Metal Core Cat, 200cell, 2.5'' inlet/outlet 4'' main body. $100
Off R33, should fit r34s I think.
EOI: Also have a set of RB25 Polished Rocker Covers. Been on car for a while so could use a re polish - $200, save yourself $250 from $450 ebay ones. Currently still on car but if anyone is interested I will take them off.
Audio
JVC 12'' Subwoofer CS-GW1200
Its BRAND NEW untouched, only thing missing is the box. Got a bit ripped
so threw it out however still in its oringinal foam box and plastic wrapping. $110
Kenwood Head Unit KDC-MP239
BRAND NEW as well, untouched, only thing missing is the box itself as it got ripped a bit so threw it out.
Still in its original foam and wrapping complete with instructions, harness, face case etc.
$150firm If I don't get for that price I'll be keeping it.
R33 GTR Centre Console compartment (compartment bit behind gear boot) ****WHITE HANDBRAKE BOOT IS SOLD****. Excellent condition, no damages. $40
OR $100 for all 4
OR $140 for BOTH
Contact 0412 297 325 Located in Sydney.
Thanks
PRICE DROP
so threw it out however still in its oringinal foam box and plastic wrapping. $99
$120 won't be keeping it after all found a spare one to use lol.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
