Lots Of Random Parts Clear Out Cheap
  • Replies 53
Autogauge smoke series mech. boost gauge $25
Hurricane High Flow Metal Core Cat, 200cell, 2.5'' inlet/outlet 4'' body $90
Whiteline Rear control arm caster adj. bushes, new, don't know what car there for but part no. is kca337 $40
R32 GTS4, R33 GTS4, Stagea Front swaybar $20
R32 GTS4, R33 GTS4, Stagea Rear swaybar $20
R33 GTR Front 5 Stud Hub Assembly perfect for 5stud conversions for GTS4s $140
R33 GTR Centre Console compartment (compartment bit behind gear boot) $40
R33 Interior Front panels Great condition, $60
R33 Interior Rear panels Great condition, $60 or $100 for everything.
R33 Front Seat Belt sets, Good condition was working perfect when removed. $65
R33 Rear Seat Belt sets, Good condition was working perfect when removed. $65 or $120 for both
R33 Series 2 VCT N/A Motor RB25DE 147kw, 114,000kms motor is in A1 condition, $400, some minor parts missing pm for details.
Drift Urethane Pod filter Blue + heat shield $20
Unknown Pod filter w/ RB25 AFM adapter. $10
Gates Timing belt used 10,000kms $40
RB20/RB25 Crossover pipe in good condition - $20
R33 Series 2 GTS4 4WD Gearbox will fit stageas as well as any other running 4wd gear including GTRs. 114,000kms in good working condition, however 4th started to slightly crunch after I had oil changed too thin, needs thicker oil and should be ok.
$390.
Contact 0412 297 325 Located in Sydney.
Thanks
Edited by OoskylineoO
$390.
I take it theres no transfer case with the gearbox?
EVERYTHING (EXCLUDING MOTOR AND GBOX) = $685
TAKING OFFERS, EVEN STUPID OFFERS, AS LONG AS THERE NOT INSANELY IDIOTIC.. OR TAKE EVERYTHING FOR $450 AND SAVE YOURSELF $285
REALLY NEED TO CLEAR THE SHED OUT FOR NEW CAR
THANKS GUYS!! :)
contact 0412 297 325, or PM for details, located in sydney
 Share
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
    • Oh for sure, I'm just recounting my thoughts 😎 I'm not what you've got there to fuzt with.... likely my first idea was on the money -- rebuild or replace connectors. You can get a lot of connector stuff here  -> https://www.rapidcables.com.au/ Didn't look in the boot of mine, because I replaced these when I renewed the pump (plastic of connectors had gone brittle) edit: what I used... https://www.efihardware.com/products/2120/Deutsch-DTM-Connector-Kit-6-Pin ...cheaper... https://www.ebay.com.au/itm/364900039138
    • In no way was i suggesting it’s your fault mate. The trailer cable has a plug that I removed. I will have a closer look, but I did remove the trailer wiring cable with the tow ball as I don’t need it on my silo. i have replaced the fuel pump already there’s no need to remove the cradle again I can see the wire colours from it in.
