Well I have 1991 r32 gts25 4 door skyline with a rb20det in it around 170 kw atw
I want do swap a enigne to a rb26dett and also make the driveline Rwd (rear wheel drive)
What would be the best way and how could you do it ?
I have a halfcut gtr r32 in mind with a g4 link ecu and for the drive line a rb25det gearbox and drive shalf also diff
Is there anything else i would need to do ? I know theres something with the sump but I need some help
So anyone who has done this before with making a RWD rb26dett please help or if know anything that could help me
I am trying to come up with track drifting car that ISN'T rb25det ( too much of the rb25det drifter )
So anything else that could help a rwd rb26dett drift r32 skyline please tell :thumbsup:
https://www.sau.com.au/forums/topic/308378-project-r32-4-door-rb26dett-rwd/
yep 25/30 is a good option, but even if you want to keep it twin turbo do a 26/30, these see big numbers built and balanced right.im just looking into this atm as im thinking of buying a laurel shell and either engine choice will be the way to go. its all about the coin in the end and how long you dont want the car off the road?
  • 4 weeks later...
So anything else that could help a rwd rb26dett drift r32 skyline please tell :cool:
done the same with a gts4 engine piece of cake
take the front cvs off and shafts out simple split pin punch and knock the pins out pull of the cvs
take the top cover off the front diff on the exhaust side of the engine free the front diff centre by grinding away one side or a couple notchs
proceed to grind the sump flush removing the housing the front diff sits in jump on the other side start grinding the bits that stick out which is the cv mount on the intake side this side needs to be grinded pretty close to the side of the sump as it needs to clear the steering knuckle at the bottom of the steering rack you will notice if you have not grinded enough as the sump will sit on the steering rack knuckle pull engine again and grind some more
all up took me about 45mins of grinding and algud bonus is you wont need to move the oil pickup and install a rwd sump
giving you 5.0litres of oil in the sump instead of 4.6 makes a big difference and the alloy sump is finned unlike the rwd crappy steel one
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
