do you mean stroked? LOL. and where do you get this from?
http://www.pharosalex.com.au/pages/33acs2.html
Table LA1 Maximum Engine Capacity
<H3 style="TEXT-ALIGN: center; MARGIN: 6pt 0cm" align=center>Weight of Vehicle</H3>
Maximum Engine Capacity (Refer to Notes Below)
Naturally Aspirated
Turbo/Supercharged
All vehicles originally weighing less than 1100kg.
Original tare mass (kg) x 0.183
max. capacity in cubic inches
Original tare mass (kg) x 3.0
max. capacity in cc's
Original tare mass (kg) x 0.153
Original tare mass (kg) x 2.5
<H5 style="MARGIN: 6pt 0cm; mso-pagination: widow-orphan; mso-list: none"></H5>
All vehicles originally weighing more than 1100 kg.
Original tare mass (kg) x 0.305
Original tare mass (kg) x 5.0
This table will be applied to all modifications.
lol it's not even a public website, and it's in another language!
this shit needs to take a trip to the Wasteland!
http://www.pharosalex.com.au/pages/33achome.html.
Was a public website for comments, on reviewing the NCOP VSB 14
Must mean if it aint for review anymore they have alredy decided.
The LA1 table has always been in the VSB14, just didnt apply to LA3 modifications, I heard they moved the table in the LA document so that it will apply.
ncop3_v2_section_la_engines_18_mar_2009.doc
Edited by bitsa
hey dumbass, that is from feb last year, and it only applies to modifications. basically it means you can't put a 427 chev engine in a gemini. has nothing to do with what the manufacturers put in their cars from the factory.
Hey thanks for the compliment, but that was when all the state heads of Vehicle Safety sections agreed to the change, or so my mate tells me.
And of course your right, every manufacturer has a V8 with a turbo or superchaged engine in their stable. Still they spent the money on R&D so they can do what they like, we wont be able to.
yes but they did the R&D on making sure that a chassis will be able to handle the power. some backyarder who puts a blown 350 chev into a torana won't know/care about whether it is going to twist the chassis every time he launches it. and he might put it in and not do any upgrades to the brakes or anything like that.
I'm not arguing for bad modifications, and I am all for manufacturers producing hot cars, turbo or otherwise.
I was just flagging impending change, to be for warned is to be for armed.
If your about to mod a V8 with a supercharger, espesially here in the west u need to know this shit.
i like this rule, looks like my mates Cluby with its 6L and the turbo kit his just brought is not goin to happen if this is true. Which means, GTR will still beat him. hahaha
Just upgrade the GTR twin turbos...
as much fun as that would be, afraid not
although in a car that light, i think the twist of the engine when you reved it meant that if you were showing off at the lights by reving the car, if you reved it too hard it would just flip the car onto its roof, LOL
Hey VSB 14 NCOP version 2 will ban V8s being blown.
3 x tare weight = max cc allowed.
Commodore v8 1600kg = 4800cc.
Bye Bye blown V8s.
Imports will rise to the top.
Learn to read first...
1600*5=8000. Can you even get 8L v8s?
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
