do you mean stroked? LOL. and where do you get this from?
http://www.pharosalex.com.au/pages/33acs2.html
Table LA1 Maximum Engine Capacity
<H3 style="TEXT-ALIGN: center; MARGIN: 6pt 0cm" align=center>Weight of Vehicle</H3>
Maximum Engine Capacity (Refer to Notes Below)
Naturally Aspirated
Turbo/Supercharged
All vehicles originally weighing less than 1100kg.
Original tare mass (kg) x 0.183
max. capacity in cubic inches
Original tare mass (kg) x 3.0
max. capacity in cc's
Original tare mass (kg) x 0.153
Original tare mass (kg) x 2.5
<H5 style="MARGIN: 6pt 0cm; mso-pagination: widow-orphan; mso-list: none"></H5>
All vehicles originally weighing more than 1100 kg.
Original tare mass (kg) x 0.305
Original tare mass (kg) x 5.0
This table will be applied to all modifications.
lol it's not even a public website, and it's in another language!
this shit needs to take a trip to the Wasteland!
http://www.pharosalex.com.au/pages/33achome.html.
Was a public website for comments, on reviewing the NCOP VSB 14
Must mean if it aint for review anymore they have alredy decided.
The LA1 table has always been in the VSB14, just didnt apply to LA3 modifications, I heard they moved the table in the LA document so that it will apply.
ncop3_v2_section_la_engines_18_mar_2009.doc
Edited by bitsa
hey dumbass, that is from feb last year, and it only applies to modifications. basically it means you can't put a 427 chev engine in a gemini. has nothing to do with what the manufacturers put in their cars from the factory.
Hey thanks for the compliment, but that was when all the state heads of Vehicle Safety sections agreed to the change, or so my mate tells me.
And of course your right, every manufacturer has a V8 with a turbo or superchaged engine in their stable. Still they spent the money on R&D so they can do what they like, we wont be able to.
yes but they did the R&D on making sure that a chassis will be able to handle the power. some backyarder who puts a blown 350 chev into a torana won't know/care about whether it is going to twist the chassis every time he launches it. and he might put it in and not do any upgrades to the brakes or anything like that.
I'm not arguing for bad modifications, and I am all for manufacturers producing hot cars, turbo or otherwise.
I was just flagging impending change, to be for warned is to be for armed.
If your about to mod a V8 with a supercharger, espesially here in the west u need to know this shit.
i like this rule, looks like my mates Cluby with its 6L and the turbo kit his just brought is not goin to happen if this is true. Which means, GTR will still beat him. hahaha
Just upgrade the GTR twin turbos...
as much fun as that would be, afraid not
although in a car that light, i think the twist of the engine when you reved it meant that if you were showing off at the lights by reving the car, if you reved it too hard it would just flip the car onto its roof, LOL
Hey VSB 14 NCOP version 2 will ban V8s being blown.
3 x tare weight = max cc allowed.
Commodore v8 1600kg = 4800cc.
Bye Bye blown V8s.
Imports will rise to the top.
Learn to read first...
1600*5=8000. Can you even get 8L v8s?
    • Ha! well, there's your problem!  Guess the last person in there didn't have great attention to detail....
    • It seems like you guys want to behave like rabid dogs, rather than gentlemen... Knowing one has jumped in on a fellow comrades near done deal, and sniped it at the last second, how can one sleep at night?
    • My wifes says we have a spare set.
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
