I have been looking at an older thread as i am about to be doing this myself, but no one in the thread states what the actual torque should be set to..
Nissan have 2 different values stated in the workshop manual it seems!
Thread is here : http://www.skylinesaustralia.com/forums/Co...an-t226987.html
Surely a few people around that know for sure?
Cheers :thumbsup:
Edited by endless
https://www.sau.com.au/forums/topic/308391-rb26-crank-pulley-torque-setting/
150Nm with ARP lube on the bolt and both sides of the washer....then 1/2 a turn more with a piece of pipe over the torque wrench handle....So Duncan was correct...VFT
from the thread...
this guy knows his shit.
Dirts method quoted above seems sound I reckon
Used a 240v electric rattle gun on mine claimed to be capable of 350 nM
Unfortunatly I may have to take it off now in the car, not looking forward to that.(Due to other issues)
Also used a new bolt an washer from Nissan wasnt to expensive either from memory
Well im yet to have an issue using this method...so id say its reasonably sound. A few guys who now use the old 150 x 1/2 method have not had an issue either.
its actually 150ft/lb...not nM...i dont know why i typed nM as i dont use that base unit very much...all my stuff is in ft/lb. So 200nM or 150ft/lb.
Edited by DiRTgarage
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
