Hi,
So I bought my Skyline about a year ago, as a bit of a project because it was pretty beaten up, and as such I got it pretty cheap. My insurance has been really good so far except that they just insured it at what I paid for it, and not a market value.
Having spent a year fixing it and spending money on it, I wanted to increase the value on my insurance to it's normal market value, or something similar, but I need to get an evaluation apparently. I'm not entirely sure about how to go about this?
Does anybody here have any suggestions as far as getting it evaulated?
NB: I'm not interested in anybody's gung-ho "f*k InSuRanCeZ mAn U dUn NeEd ThAt ShIz" ideas.
Cheers,
Mods: Sorry if this has been covered, couldn't find anything searching.
https://www.sau.com.au/forums/topic/308437-insurance/
Hi,
Cheers,
Hi Tim
You need to go to a dealer to get a valuation from them and some dealers will charge you for it as well.
If you know a dealer (preferably one that sells Skylines) then maybe they can help you.
If you know anyone at C-Red then they may be able to help as last time I checked they had a Dealers License.
Hope this helps
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5090225
Cheers,
Thanks Rod, I'll be looking into that when I get home. Just out of curiosity, what do people think the market value actually is? I saw a completely stock 33 [i think this was actually less than had come out of the factory, had lots removed] for for 15k a few months ago.
Thanks for the help
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5090383
The ol' "mildly modified 33"? Reasonably good nick.
Was more interested in the market value that insurance companies will be going with like Kaido is talking about.
I renew my insurance in in dec 09 and Just Car had the market value of my r33 gts-t S1 1993 at $11,000 :P
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5090470
Any luck with this Tim? I am wanting to do the same thing, i am with JustCars as well and they will only insure my car to $10000 :/
But after i do the engine swap then i will want more cover than that. What other companies insure gray imports? Shannons won't insure me because im under 25
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5094248
When I swapped my insurance from just cars to sgio they said they could do it at market value which was 10k or what I paid for it which was 8.5k, so mine is insured for 10k even though they know i payed 8.5k for it over 6 months ago. This was for third party fire+theft btw
Edited by Crackfox
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5096723
My car was insured with JC for $2k (car value $10k), when I came to renew the policy early this year I used their website thing & added some of the extra mods I did to the car (exhaust, POD, SAFC 2, intercooler & boost controller) they upped my car's insured amount from $10k to $11.7k & didn't change my premium? Are they actually being generous or their computer software must be bugged?
https://www.sau.com.au/forums/topic/308437-insurance/#findComment-5104351
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
