  • Replies 210
This is what's still available.
Rack pinion $150
master cylinder and booster $150
Hubs x4 $600
mag wheels 235/40z/r18 90% thread on tires $700
dba 4000 series slotted rotors x4 $450
3.5" stainless steel exhaust from turbo back $600
red callipers with pads x4 $500
auto with shifter and computer $500
In car DVD player $300
diff $350
carbon fibre pod filter $100
RH door shell in perfect condition $100
Rear strut brace $150
stock smic $50
drivers seat $100
dual gauge pillar mount with boost and air/fuel ratio gauge $170
stock floor mats $100
seat belts $120 for the lot
RH door trim $100
RH door mirror $100
electric window motor $100
parcel shelf $70
after market spoiler $200
rear and front wiper motor $100
RH door glass $70
This is all i have left for sale!------->
Rack pinion $150
Hubs x4 $600
diff $350
stock smic $50
drivers seat $100
RH door trim $100
RH door mirror $100
parcel shelf $70
RH door glass $70
veilside front bar s1 $200
veilside side skirts $150
GT-R cams $150
Edited by perry_r33
make some offers guys on the running gear and ill let u know and no low ball offers either
Edited by perry_r33
Hubs x4 $600
In car DVD player $250
diff $350
stock smic $50
drivers seat $100
RH door trim $100
RH door mirror $100
parcel shelf $70
RH door glass $70
GT-R cams $150
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
