  • Replies 210
Hey mate,
Just wondering if you still had the drivers side power window switch trim and the coin holder? If so how much? .
Edited by Jaredo
few bits and pieces left guys!!!!!!!!
Parts still available
Hubs x4 $500
dba 4000 series slotted rotors x4 $400
3.5" stainless steel exhaust from turbo back $500
red callipers with pads x4 $400
auto with shifter and computer $500
diff $350
carbon fibre pod filter $100
Rear strut brace $150
stock smic $50
stock floor mats $100
seat belts $120 for the lot
RH door trim $100
RH door mirror $100
electric window motor $100
parcel shelf $70
after market spoiler $200
rear and front wiper motor $100
  • 5 weeks later...
hey
man that sucks when cops just put the blame on performance cars ><.
anyways, i'm looking for the sun visors and cluster if its still available. assuming they in good condition, can you pm me plz.
cheers
Edited by Gordoskyline
Couldn't be arsed going through 10 pages
But anyways have you got dash surround and gear surround still?
Drivers door with all the trim and window gear ?
and where abouts in melb are you located
this is all i have left everyone
Hubs x4 $500
diff $350
stock smic $50
RH door trim $100
RH door mirror $100
parcel shelf $70
  • 1 month later...
hi jw do u still have parts for sale ...
if so i was wondering would beable to see the front strut mounts ? if so how much thanx
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
