  • Replies 210
Parts still available everyone price drop on hubs callipers and rotors
Hubs x4 $500
dba 4000 series slotted rotors x4 $400
3.5" stainless steel exhaust from turbo back $600
red callipers with pads x4 $400
auto with shifter and computer $500
diff $350
carbon fibre pod filter $100
RH door shell in perfect condition $100
Rear strut brace $150
stock smic $50
drivers seat $100
dual gauge pillar mount with boost and air/fuel ratio gauge $170
stock floor mats $100
seat belts $120 for the lot
RH door trim $100
RH door mirror $100
electric window motor $100
parcel shelf $70
after market spoiler $200
rear and front wiper motor $100
RH door glass $70
Parts still available everyone!!
Hubs x4 $500
diff $350
stock smic $50
drivers seat $100
RH door trim $100
RH door mirror $100
parcel shelf $70
RH door glass $70
ay man yea got the rear view mirror and drivers side mirror $100 come get them haven't got the cooler piping call or text me on 0432-062-780
Hubs x4 $500
3.5" stainless steel exhaust from turbo back $500
diff $350
stock smic $50
RH door trim $100
RH door mirror $100
parcel shelf $70
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
