heya,
got a quickie for ya's
Installed 6x 550cc Siemens injectors into my rb26dett
The injectors came with 2x orings up top and 1 grommet down bottom.
For installation, does 1 oring go inside the fuel rail when slipping in the injector, and the other oring sits outside? ie squeezed between fuel rail & injector?
creates an inner seal inside the fuel rail with oring
creates an outer seal between injectors and rail.
is this correct? or is only 1 oring used (inside the fuel rail)
https://www.sau.com.au/forums/topic/308448-r32-gtr-injector-installation/
I have the seimens 550s. Mine came with a large single o-ring at the top, a couple of which leaked after a short while. When i pulled them to check they had torn. Replaced all six with the factory o rings pushed down to the bottom of the mounting area, and they have been perfect since.
thank you.
I used a little bit of degreaser on the orings to help slide them in ok.
One oring at the top inside to create an internal seal, another lowered onto the injector body to create an external seal where the injector body meets to fuel rail
orings were the same size tho. no big deal. once tightened down with the 2 fuel rail bolts it seems ok.
Havent fired it up yet, working on fuel system atm
(surge tank, braided fuel line, external 305lph walbro, internal gtr pump, + just finishing off radiator upgrade & oil filter relocation kit)
awaiting a $15 gtr remap chip, then will try firing up the engine
thanks again for the advice
  Tangles said:
quickie
with the injectors installed being 550cc, and dead stock ecu...
the car "shouldnt' start, right?
it may start but be very very rich. If it doesn't start it would have already fouled the plugs.
careful with the grease used, it must tolerate petrol. pulled my fuel rail off the other day and the injectors were siezed in place, the grease had broken down.
next time just wd40 for me
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
