1995 R33 GTR V-Spec Midnight Purple
For those of you that followed the build thread, here's the finished product. (clutch was able to be adjusted and now easy as to drive)
Totally regretful sale but im just not going to be in the country to enjoy it.
Fresh total mechanical rebuild from intercooler to exhaust tip, just run in.
HKS step2 2.8 stroker, full counter crank and rods kit, CP pistons.
Brand new head from Nissan, Jun 272 in and ex cams, 10.8mm(?) lift, special retainers and all the jazz needed to support the cams and high revs, heads extensively ported.
Big dollar hypertune plenum and single throttle body setup
Custom alloy breather tank etc
Jun oil pump, N1 water pump, cant recall the brand of balancer, but its a good one.
Trust sump extension.
Turbonetics GTK-850 turbo and big Turbonetics external gate
OS Giken 2 way front diff
OS Giken cross mission 5spd gearset with input shaft 800+hp rated, quick shift kit
OS Giken triple plate clutch 800+hp rated
Carbon fibre super lightweight tailshaft (not currently fitted)
ATTESSA system fully inspected with all fluids changed
V-Spec active rear diff
engine made 760HP on engine dyno at ~25psi with screamer pipe
Current street setup with wastegate plumbed back into HKS 4inch exhaust
Huge alloy radiator, disgustingly thick Trust intercooler.
Fuel system to cater for 1000hp, in boot setup as in pics,
1000cc HKS injectors,
HKS fuel rail,
splitfire coilpacks
Motec M800 ECU
Genuine 18inch Impul rims all round with new tires
V-Spec shocks with Lovells springs
V-Spec Brembo's all round
Midnight purple paint in excellent condition. Will try and get some pictures with better light to show off the purple.
Excellent condition original interior with almost no wear in the usual places (seat bolsters, steering wheel etc)
66850kms on the car, 1050kms on the engine including the run in
12 months SA Reg including custom silver on black godzilla plates
All mechanical parts brand new and all work done exclusively by James Sutton at Nisspeed Performance Engines.
Silly money spent and not used since run in. NO EXPENSE SPARED ON THIS BUILD.
Relocating overseas, asking price $45,000, however ALL GENUINE OFFERS CONSIDERED.
Test pilots forget it, will not be entertained. Genuine buyers only.
I WILL NOT BE CHECKING BACK HERE REGULARLY. Please direct all enquires to email:- [email protected]
Edited by SLY33
^^yes I do have a stubby shifter but this big one is real easy to shift.
Balancer is ATI
Awesome power, car sounds like a jet taking off. Has an idle like no other street GTR ive heard, can really hear the cams. Will try and hook up a youtube link...
2 Way front diff means it doesnt change lanes on you from torque steer when you nail it, this thing tracks straight ahead, just hold on!
Now listed on carsales, more pics going up soon.
After bring it home Ive driven this car just TWO short times around my suburb! I fly back overseas tomorrow for good. Spent a BOMB building this car, this is how people get crazy bargains. Just try building it yourself, set a budget and you end up doubling it once your done. And dont forget the headaches that you didnt see coming!
This car is COMPLETE. Real sweet to drive.
Edited by SLY33
f**k!
for my sake, i hope its still for sale in 6 months time!
but i wont be suprised if its gone and youll we hoping its gone lol
goodluck!
Edited by Import S13
    • Hi everyone, just looking to see what's available in the GTR seat options, testing the waters on what's available. Wanting a driver's seat to replace my old school OG jap race seat, going to re-register the car so need a factory seat. Prices currently seem to go from $300 to $2k for a driver's seat. What's options are there, that's good condition and actually a realistic price? Located Brisbane. Thanks
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
