I've got a rattle in the passenger side rear end , sounds like a blown shocky or loose rear strut , but it aint , because I've got new rear struts and I changed them myself and I know they aint loose.
It dosen't do it all the time but I can bring it on by giving it a bit if boot on a sharp lefthander as long as there is a bump in the road on the corner--you would be amazed at how many corners do have a bump in them.--or maybe not. :P
I've jacked up the back at both sides and can't get anything wobbling when tugged or bushes hanging out or obviously fraked.
Any ideas anyone ???
Oh yup ita an R34GTT.
https://www.sau.com.au/forums/topic/308475-ass-end-rattle/
after I up-specced my sway bar and exhaust I had the zaust swinging a little when turning and/or on a bumpy surface, so I got the occasional tap between the two. Solved the problem by getting some hi-temp silicon (rad pipe would do) and zippy tieing it on so that any clang is minimized... :P
try you'r zaust and bash it around next time it's up... see if that makes a noise....
https://www.sau.com.au/forums/topic/308475-ass-end-rattle/#findComment-5090644
after I up-specced my sway bar and exhaust I had the zaust swinging a little when turning and/or on a bumpy surface, so I got the occasional tap between the two. Solved the problem by getting some hi-temp silicon (rad pipe would do) and zippy tieing it on so that any clang is minimized... :D
Zorst AAAAAAAAARRRRGGGGGGGH :blink: gotta big oval 3.5" in and out Varex at the end of my system -culprit---I'm bettin' it is. Thanks mate.
KeeperPosted Yesterday, 05:50 PM checked the subframe mounting bushings??? look for crap dripping out of the front ones, looks like jelly.
Thanks for that-just checked and still dry as- no aeroplane atall- good call though I'll keep an eye on them as the front castor rods sprang a jelly not long ago so as the rear subby's are jelly too {which I didn't know)they may be going to follow suite :cool: .
Edited by BASHO
https://www.sau.com.au/forums/topic/308475-ass-end-rattle/#findComment-5092241
