Hi there.
Just wondering if anyone knows exectly what this part do? I could be searching with the wrong keywords but I can't find much details about this part in the forum and nothing much in the R34 Service Manual as well.
The tube connecting to mine has broken off and i've just reglued it back. I was looking around for used parts and and neo32 mentioned that it's only for boost cut?
I just want to know more about it before i just remove it altogether.
The part has the following details one it:
PS66-01
HITACHI BOOST SENSOR
It sits near the firewall and photos are attached on how it looks like. It is connected directly to the vacuum(orange thing)
Thanks.
Sue
https://www.sau.com.au/forums/topic/308481-r34-gtt-boost-sensor/
its just for an overboost protection that the stock ecu has. if the little plastic nipple has broken off the bottom of it don't worry, just block off the vacuum line going to it, and leave the sensor plugged in. if you unplug it and remove the sensor it will throw a DTC and the engine check light will come on.
DO NOT DO THIS.
The boost sensor also is referenced mixture control (extra tables, not present in R33 ecu's), blocking it off immediately results in the car running 1-2 A/F's LEANER.
wow ^^^ that could be dangerous. Obviously 34's much more advanced in ecu
On a 32 it just does the stock boost gauge in the dash, unplugging the wire connection seems to have no effect on the tune what so ever.
they have one for the for the gauge aswell . . if it rund disgustingly rich 10 to 1 not un common then unplugging it will give a nice 12 to 1 . lol rangi but there could be somtethign behind it . there have beena few stageas that people bought with it blocked off and they havent blown up yet?
DO NOT DO THIS.
Shouldn't be a problem leaving it disconnected and getting the car retuned? Ignoring the computer codes/engine light or are there any other problems with this?
Provided it is tuned with it unplugged or blocked, it is fine. But dont unplug it unless it was set up to run that way especially with a remap or safc etc.
DO NOT DO THIS.
just curious trent as to which tables you are talking about? is it one that can been seen from in nistune or a background ecu table that can't be seen? i honestly didn't notice any difference in AFR's once disconnecting mine.
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
