Hey guys, i have been having issues with my gtr it seems to pull slightly to the left, even after wheel alignment etc apparently there isnt enough adjustment to stop it and will need more. my steering wheel also is slightly turned to the left most of the time but u will be driving along down the road then the car will start to track towards the right all of a sudden then straighten it self then to the left again. i have removed the hicas so it cant be that, i have been told by a few people who have looked at it that inside the steering rack, the valving etc can be stuffed causing it to fight against the driver, which i can feel through the wheel when driving. feels like an hydraulic style turn of the wheel like power steering.
If you let go of the wheel whilst driving along it will pull to the left mostly but then turn it self towards the right all of a sudden the go back straight again. it does this regularly.
any other hints on what to check before getting rack rebuilt? has anybody had a simlar problem?
Cheers
85URK
Daz
https://www.sau.com.au/forums/topic/308505-steering-rack-rebuilder-se-qld/
Hey mate, if you're around the redcliffe area, i'd recommend Frawley's Engine Reconditioning. Don't let the name fool you. He also does reconditioning on power steering racks. He also does exchanges too if he's got one sitting there that is. He does a good job and we send all our steering racks to him to do.
His address is 28a Grice St Clontarf QLD 4019. Phone (07) 3284 3224
Good luck and I hope this helps
thanks mate im on sunshine coast, but its not hard to send stuff to brissy via couriers etc
il give them a buzz. redcliffe is closer then bris anyway.
Cheers for that.
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
