car is perfect
a lot mods are nearly new
engine only done about 7000KMs after rebuild
well balanced mods GTR
Genuine kms
clear history
every 3000kms service, use best oil. eg: RP engine oil, Motul rbf 600 brake fluid, full syn fluid everywhere:)
selling reason: want a quiet sport car.
price: $85000 if you think its expensive please read mods list carefully
any inspection welcome:)
mods list:
Engine: (7000kms old engine)
1. JE pistons/rings
2. H beam PRECISION rods
3. ARP racing hard stud/bolt
4. ACL head gaskets
4. AcL racing bearing set
5. valve spring
6. nismo water pump
7. nismo oil pump
8. tomei camshafts in/ex
9. tomei cam gears
10. clear cam cover
11. Splitfire super direct ignition system
12. NGK spark plug
13. nismo baffle plate
14. tomei oil restrictors
15. oil catch can
16. ARC front plate
17. nismo radiator cap
18. nismo oil cap
cooling
1. trust oil cooler front
2. nismo intercooler
3. arc radiator 36mm
4. arc cooling panel
5. billion racing PS tank
6. samco radiator hose set
exhaust
1. hks dump pipe
2. hks front pipe
3. trust pe II drag 94mm catback (3000kms old)
4. high flow cat (3000kms old)
Electronics:
1. apexi avcr
2. apexi pfc
3. 2* z32 afms
4. trust oil pressure gauge (2000kms old)
5. trust fuel pressure gauge (2000kms old)
suction:
1. trust T517z kit 8cm
2. nismo piping kits
3. apexi power filter kit for z32
4. apexi carbon airbox
fuel system: (the whole fuel system less than 3000KMS except nismo intank fuel pump)
1. tomei fuel rail
2. 3L surge tank
3. 2* bosch 044 fuel pump
4. nismo intank fuel pump
5. 6* Power Enterprise 800cc injectors
6. sard fuel reg
7. 2* bosch fuel filter
9. all fitting
suspension & brake & drivetrain
1. alcon 6piston brake kits 365mm disc F (2000KMS old)
2. alcon 4piston brake kits 335mm disc R (2000kms old)
3. adr prove brated brake line (2000kms old)
4. DS2500 PADS all around (2000kms old)
5. DMS 50mm 2way coilover kits (1000kms old)
6. rays Progressiv ME 19*10.5 +12
7. 275 30 19 595SS (near new)
8. nismo big operating cylinder
9. nismo super coppermix twin plate clutch (7000kms old)
10. cusco 1.5 way LSD (front)
11. nismo short shift kit.
12. PILLOWBALL UPPER MOUNT (F&R) (1000kms old)
other
1. nismo clear side light
2. nismo front bar vent
3. nismo carbon look pillar
4. nismo side skirt and rear pads
5. DVD player
460HP 1.45bar 385hp 1.1bar very very safe tune, knock no more than 20 on PFC. this car still have a lot potential. want more power? just give some more boost.
some more i can't remember.
the suspension make some noise(the noise from the valve which is normal for DMS 50mm), if you don't like it i can give bilstein 14b coilover for free. the bilstein doesn't make any noise and very good condition.
PM me if interest.
Edited by Nosure
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
